Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    ROG Member Array g051051 PC Specs
    g051051 PC Specs
    MotherboardROG Zenith Extreme X399
    ProcessorRyzen Threadripper 1950X
    Graphics Card #1Geforce GTX 1060
    Apr 2018
    23
    Any info on the 1901 firmware?
    1901 is now offered on the Driver & Tools page, but not on the BIOS & FIRMWARE page (still lists 1701 as the latest). No description of changes or release notes. Anyone know of any info on this new firmware version?
    Edit: This firmware is for the original Zenith Extreme, not the Alpha.
    Edit 2: release notes have been added:
    ROG ZENITH EXTREME BIOS 1901
    Improve hardware monitoring compatibility with 3rd party applications.
    Fixed a boot issue when using a Quadro K6000 GPU.
    " Before running the USB BIOS Flashback tool, please rename the BIOS file (ZE.CAP) using BIOSRenamer.''
    ROG Member Array
    Apr 2019
    6
    Quote Originally Posted by g051051 View Post
    I just installed it.
    This version seems to be even more picky with RAM.
    On the previous version, I could run my G.Skill F4-3200C14Q-64GTZR Trident Z RGB DDR4-3200 64GB RAM kit B-Die (16GB x 4) manually @ 2933, 14-14-14-34, 1.35v.
    In this version, I can no longer do the above setting.
    It's currently left at Auto (2133) @ default timings and voltages as any other settings would prevent the Zenith Extreme Alpha from booting / posting, giving out a Press F1 key Memory Error.
    ROG Enthusiast Array
    Oct 2012
    11
    31
    Quote Originally Posted by delancyst View Post
    That is the same exact memory that I have. I am so happy I saw this before I flashed because I was just about to do that. It sounds like ASUS ducked up memory training. Have you been able to find a working solution or are we SOL? Did you try to use UEFI/BIOS flashback to 0405 or the original release version? You can use flashback by renaming the UEFI/BIOS file to ZEA.CAP and then using the flashback feature at the back.
    Mar 2016
    12
    67
    Judging by release notes on the Alpha, I'd assume this new BIOS brings :
    Oct 2012
    11
    31
    So, the gentlemen or lady that flashed the new UEFI/BIOS - were you able to successfully flash back to the prior release to resolve the memory problems?
    ROG Member Array
    Apr 2019
    6
    Quote Originally Posted by dejanh View Post
    Sorry for the late reply.
    My 2950x is speced at 2933mhz on AMD website, I’m not sure what Asus did but they should allow us to at least run the ram at 2933.
    I have not tried flashing back yet. I will try tonight.
    Interestingly, with 1901, i’m not seeing anymore random Explorer ‘referenced memory’ errors on shutdown.
  7. #7
    ROG Member Array
    Dec 2018
    23
    When I bought my Zenith Extreme I installed 1061 Bios version and everything worked well except a minor issue about disabling led light. After few months I upgrade bios to 1071 and my pc have hard shutdown randomly issue. I have been waiting for new bios and now i see people complain about memory issue. I'm starting to hate Asus.
  8. #8
    Oct 2017
    32
    Hmm and I just hopefully fixed my very random instability on my third zenith extreme board RMA while at 1701 (older bios versions didnt help). First boot random bluescreen after hours, very rare shutdown while browsing web, reboots seemed to be rock solid. In the end it seems it needed a bit more volts (according to bios readings) than previous boards for CPU (3700) and SOC and some ram+ram slot cleaning to pass y-crunch bechmark+stress test, HCI memtest passed before.
    64GB/4 3200Mhz (slightly tighter) 14 14 14 14 28 42...CR2 1.365(~1.372) GSkill trident z non RGB. Tried and tested on previous boards.
  9. #9
    ROG Member Array
    Apr 2019
    6
    I am back on BIOS 0405.
    Just ran 2 passes of 'standard' Windows Memory Diagnostics without problem.
ID:	80799Click image for larger version.
  10. #10
    ROG Guru: White Belt Array
    Jan 2019
    77
    I can confirm Asus zenith extreme alpha bios has broken memory support. Everyone is advised not to update and report this issue to asus. i don't know what those freaking engineers are doing ... regressing this board with each releqse.
