Results 1 to 10 of 15
06-20-2019 09:36 PM #1
- Join Date
- Mar 2018
- Reputation
- 10
- Posts
- 15
Any solution to the immediate ramp of of fans using Q-Fan or FanXpert4?
My fans are ramping up if I pass the temperature threshold, which happens basically anytime I open Chrome etc. ITs super annoying, I dont need my fans spinning up and back down just because my cpu spiked for a milisecond. Has anyone found a solution to this?
06-21-2019 07:12 AM #2
- Join Date
- Jul 2017
- Reputation
- 10
- Posts
- 10
There is an option for Ramp up time in seconds and Ramp down time, i have set mine to 25 sec before it will ramp up the fans.
06-21-2019 06:10 PM #3
- Join Date
- Mar 2018
- Reputation
- 10
- Posts
- 15
The step-up time doesnt work though. It has been documented in this thread: https://rog.asus.com/forum/showthrea...n-step-up-time
The fans completely disregard the step-up and down values.Last edited by Squidmaster7; 06-21-2019 at 06:14 PM.
06-22-2019 04:11 PM #4
Adrian1983 PC Specs Motherboard Asus Maximus XI Hero Processor I7 9700K @ 5.1 Memory (part number) CMK32GX4M2D3000C16 @ 3600 32gb Graphics Card #1 Zotac RTX 3080 Trinity Sound Card Hdmi Monitor Sony 55" Tv Storage #1 Samsung 970 Evo Plus X2 Storage #2 Samsung 840 Pro CPU Cooler Corsair H150i Pro Case Fractal Design Define S2 Vision RGB Power Supply Seasonic focus gold 850w Keyboard Logitech G915 Mouse Logitech G703 Headset Logitech G935 OS Windows 10 x64
- Join Date
- Jun 2019
- Reputation
- 10
- Posts
- 50
06-22-2019 10:25 PM #5
mdzcpa PC Specs Motherboard Crosshair VIII Dark Hero Processor 5900X 4.6ghz All core 1.3V, 5ghz single DOC Memory (part number) Gskill NEO 3600 CAS 14 32GB (4x8) Graphics Card #1 ROG Strix RTX 3080 Sound Card On Board Monitor ROG PG348Q Storage #1 Samsung 980 Pro M.2 512GB for OS & APPS Storage #2 Samsung 980 Pro M.2 1TB for GAMES CPU Cooler ROG Ryujin 360 Case Phanteks 500A Mesh Power Supply Seasonic Prime 1000W Titanium Keyboard Corsair K70 LUX RGB Mouse Corsair M65 RGB Headset Corsaur Virtuoso Mouse Pad Corsair MM300 Wide Desk Mat OS WIN 10 Pro Network Router Linksys VELOP Accessory #1 ROG 751JY Laptop for Moobile Gaming Accessory #2 Koolance EXC-800 Chiller Accessory #3 25+ years of overclocking
- Join Date
- Nov 2011
- Reputation
- 80
- Posts
- 999
The delay in Fan Expert works if you wish to use that.
07-26-2019 12:26 PM #6
- Join Date
- Mar 2018
- Reputation
- 10
- Posts
- 15
07-26-2019 03:48 PM #7
instyne PC Specs Motherboard ROG Maximus Xl Formula Processor i9-9900K Memory (part number) CMW32GX4M4C3200C16W Graphics Card #1 Gigabyte GeForce RTX 2070 Gaming OC White 8G Sound Card ROG SupremeFX 8-Channel HD Audio S1220 Monitor Sony XBR65X900E 65-Inch 4K Ultra HD TV Storage #1 Crucial - P1 1 TB M.2-2280 SSD x 2 Storage #2 Western Digital - Black 4 TB 3.5" 7200RPM CPU Cooler TT Water 3.0 360 ARGB SYNC Premium Edition Case Corsair - 680X White ATX Full Tower Case Power Supply Corsair - RMx White 850 W 80+ Gold Certified Fully Modular ATX Power Supply Keyboard Logitech Bluetooth Multi-Device K480 Mouse Logitech MX Anywhere 2S Wireless Mouse Headset/Speakers SONY RM-ANP109 Sound Bar OS Windows 10 Pro Network Router Linksys AC4000 MU-MIMO Tri=Band Router Accessory #1 Corsair HD140 RGB x 5, HD120 RGB Accessory #2 Corsair Commander Pro, RGB Fan LED Hub Accessory #3 Lighting Node Pro x 2, 8 RGB Lighing Strips
- Join Date
- Oct 2012
- Reputation
- 10
- Posts
- 4
I've had my build running for just over a month. I'm having the same problem, my cores highest temp is 33C while I'm typing this. The fans have cycled up and down 5 times, I'm very interested in an answer myself.
07-26-2019 05:42 PM #8
Carlyle2020 PC Specs Motherboard Asus Maximus XI APEX Processor gaming9900ks@5.2/avx 0/ adaptive vcore / 1.35+0.020 offs/LLC5/ac ll 0.01/TVB off/power saving on Memory (part number) Gskill 4400 CL16 /65k r /65k w / 60k c Graphics Card #1 3080 ftw ultra /pads on backplate Sound Card Xonar STXII mods:3xLME 49720NA Monitor LG 38GL950G / -HDR / +madVR Storage #1 2TB 970evo plus nvme Storage #2 1TB 960evo nvme +2x 1tb evo 860 hw-sata-raid CPU Cooler arctic freezer II 280 Case Unique Silverstone FT2 dampened up the wazoo V2.0 Power Supply Seasonic TX-850 Keyboard Cherry KC 1000 on top of a cherry MX1 for ergonomics :) Mouse MX Master 3 Headset Sennheiser PC360 + Philips X2HR Headset/Speakers A250 / cause LG was stingy OS Win 10 64bit Network Router yeah right... Accessory #1 Silverstone EBA01 headphone stand / black Accessory #2 radio Keyfob to turn on and off Accessory #3 4 bay fantec /10tb red/+scrap
- Join Date
- Mar 2018
- Reputation
- 17
- Posts
- 155
Maybe try something like this:
CPU Q-Fan Control - PWM Mode
CPU Fan Setup - 25 sec
CPU Step down - 8.5 sec
My :
CPU FAN Lower Limit is 200 RPM
Manual Fan Profile
CPU upper Temp: 55
max duty cycle: 100
CPU middle Temp: 50
middle duty cycle:80
CPU lower Temp: 45
Minimum duty cycle: 37
Works for me. Then again i use anything BUT Chrome since it tracks more than any other browser out there.
Good luck !
07-27-2019 08:05 PM #9
- Join Date
- Jun 2019
- Reputation
- 10
- Posts
- 50
Yes that's what i mean, it was annoying the fans revving up every time you do a simple task or opening of an app, it did that here until i found 6.3 sec delay to be optimal for me for light loads, if the cpu temp stays at your target temp for more than 6.3 i think it is then the fans kick in. i've never had an issue with the XI hero or the VIII hero i owned before this.
08-02-2019 06:40 AM #10
Holypriest PC Specs Motherboard Asus Maximus Hero X wifi Processor i9 9900k Memory (part number) G.Skill Trident Z RGB LED DDR4 3200MHz 4x8GB Graphics Card #1 Colorful 1080 ti Vulkan AD Graphics Card #2 Colorful 1080 ti Vulkan AD Monitor Acer Predator x34 @100 Hz Storage #1 Samsung 960 Evo M2 500 Gb Storage #2 Intel 660p M2 2 Tb CPU Cooler EK Waterblocks EK-FB ASUS M9H Monoblock Case Corsair 460 X Power Supply Corsair RM 850x Keyboard Ducky one erefic Mouse G 903 Headset Hyper X Cloud flight Mouse Pad Logitech Powerplay OS win 10 / Mint 19
- Join Date
- Nov 2013
- Reputation
- 10
- Posts
- 17
I have recently bought the Hero X, and i run it with a 9900k, and custom cooling loop, and
having the same problem, as many others with the ramp ups and downs and trying all the solution's in this thread, and also in the thread linked above https://rog.asus.com/forum/showthrea...n-step-up-time
I finally downloaded the program Argus monitor, recommended in the other thread, and without any prior knowledge, and a short youtube video, i figured out how to get my fans, nice and quiet, took me about 30-45 minutes of playing around and making a curve.
And it is so nice to have found a working solution.
I only got the program last night, so I am trying the 1 month FREE before i make a purchase, and to see if it holds up, but so far I am a happy camper.
