BSOD: stopcode MEMORY MANAGEMENT
dusank
My PC crashes at least once daily and I get a Windows 10 Pro BSOD with the error message stopcode MEMORY MANAGEMENT.
I have run windows memory diagnostics for several hours but no errors were found with my memory.
Any idea how to diagnose the source of this problem and how to solve it?
8 REPLIES 8
MeanMachine
unable to address your issue due to access denial
We owe our existence to the scum of the earth, Cyanobacteria
My System Specs:
MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
CPU:
AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
[/HR]
Not sure what you mean by this.
MeanMachine
There is a Forum bug denying access to some threads, Why this is happening, well we don,t know and it's been happening for a while.
I tried to respond with information for you without success. There is a thread Äccess Denial".
My System Specs:
CPU:
[/HR]
raju2529
share your memory dump files to online storage and paste the liNk here1. I will analysis the cause of BSOD
Intel i5 7200U_ Nvidia 940MX _Windows_11_Enterprise_64bit_22H2_buildno_22621.754
Thank you very much for your help.
I try to upload the dump file for you but I cant find the file "c:\Windows\MEMORY.DMP".
My startup and recovery options are set to "Automatic memory dump", dump file "%SystemRoot%\MEMORY.DMP".
My "c:\Windows\Minidump" folder is also empty.
I've updated to the latest Crosshair VI Extreme BIOS (7003), loaded Stilts Safe 3200MHz Settings leaving the CPU non-OCed and have run AIDA64 System Stability Test with only "Stress System Memory" turned on.
After very few minutes the SST goes red with the error message "Warning: Hardware Failure Detected! Test Stopped".
Does this imply bad memory sticks? Shall I RMA?
hereric
Google "1usmus Dram Calculator"
download version 1.5.1. go to the "memory benchmark" tab, set for max memory and run that to 10000%.
If you have any errors, your memory is not stable. windows memory diagnostic isn't really stressful enough to catch all errors.
I have downloaded 1usmus 1.5.1 from various sources but when I try to run the benchmark I always get an exception:
************** Exception Text **************
System.MissingMethodException: Method not found: 'UInt64 HCIMemTestController.Controller.GetFreeRam_cut()'.
at Ryzen_DRAM_Calculator_1._5._0.MainForm.MEMbench_Run_BTN(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.3416.0 built by: NET472REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Ryzen DRAM Calculator 1.5.0.6
Assembly Version: 1.5.0.6
Win32 Version: 1.5.1.0
CodeBase: file:///C:/Tools/Ryzen%20DRAM%20Calculator%201.5.1/Ryzen%20DRAM%20Calculator%201.5.1.exe
Win32 Version: 4.7.3324.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.7.3056.0 built by: NET472REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
MetroFramework
Assembly Version: 1.2.0.3
Win32 Version: 1.2.0.3
CodeBase: file:///C:/Tools/Ryzen%20DRAM%20Calculator%201.5.1/MetroFramework.DLL
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Tools/Ryzen%20DRAM%20Calculator%201.5.1/HCIMemTestController.DLL
System.Windows.Forms.DataVisualization
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.DataVisualization/v4.0_4.0.0.0__31bf3856ad364e35/System.Windows.Forms.DataVisualization.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
Win32 Version: 4.7.3362.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Management
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
System.Data
Win32 Version: 4.7.3260.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.7.3056.0 built by: NET472REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Any idea how to overcome this?
