GL702VSK problem with external monitor resolution
sanchek
Cant use native 4k resolution with miniDisplayport - HDMI adapter on external monitor, but it works if I connect HDMI directly. Any ideas?
xeromist
Could be the adapter does not support 4K or maybe the port doesn't support it when using an adapter. Make sure you are comparing the same refresh rate and color depth as well.
