Results 1 to 2 of 2
    New ROGer Array
    Jun 2019
    6
    NVMe heat thermal pad.
    Hi, I have a Maximus X hero with a NVMe 970 Pro from Samsung installed. I was wondering does the included heat sink/shield thing that comes with the board actually help reduce heat levels of the NVMe drive? Or does it make it worse?
    I ask because I noticed that my NVMe drive gets significantly hotter than a traditional SATA6 SSD. For example my SATA6 SSD would never go over 40c but sometimes I see my Samsung 970 pro at 55c.
    So what;s the deal on that included heat sink shield thing? My guess is that it makes heat worse because there's less air flow to the bare NVMe drive itself?
    ROG Guru: Brown Belt Array davemon50 PC Specs
    davemon50 PC Specs
    Laptop (Model)Asus G752VY-DH72 (17") and Asus G752VT-DH74 (17")
    MotherboardAsus ROG LGA2011-v3 Rampage V Edition 10, x99 EATX
    ProcessorIntel Core i7-6950X Extreme 10-core 25MB Cache 3.0 GHz
    Memory (part number)Corsair Vengeance LPX Red DDR4 DRAM 64GB-4x16 3333 (CMK64GX4M4B3333C16R)
    Graphics Card #1Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Graphics Card #2Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Sound CardAsus SupremeFX Hi-Fi Audio DAC
    Monitor(2) Dell UltraSharp U2515H 25-inch monitors
    Storage #1(3) SSD's - Samsung 960 1TB M.2, Intel 535 480G, Intel 510 250G
    Storage #2(3) HDD's - Western Digital Caviar Black 2TB 3.5-in SATA III 64MB Cache
    CPU CoolerCorsair Hydro Series H80
    CaseCorsair Obsidian Series 650D Black, ATX, Mid Tower
    Power SupplyCorsair Digital AXi-Series AX1200i (1200W) 80+ Platinum Rating
    Keyboard Logitech Wireless K360
    Mouse Logitech Wireless MX Anywhere 2
    Headset HyperX Cloud II
    OS Windows 10 Pro 64-Bit
    davemon50's Avatar
    Apr 2017
    45
    1,002
    Your temps are in the right range. The NVME drive will always run hotter than your SATA6 drive just because it's doing so much more work per time interval.
    Regarding your heat sink I suppose it depends on which YouTube video you watch and believe. Your Samsung drive actually already has a heat sink (or at least a heat dissipation layer) on it because the sticker/label they attach to it is layered and includes a copper layer for that purpose.
    I don't use a heatsink on mine in my desktop (I do, however, in my laptops). The reason is because my desktop case has really good airflow. My opinion is that the label dissipation of the Samsung along with good airflow over the drive to take away the heat is adequate. If you have poor airflow over your drive then it probably won't make a difference to you whether or not you use a heatsink, your drive life will still suffer.
    Davemon50
