no not really .. I comes out of the box as red lighting.
I have to have it plugged into my add header to get it so change colors. Now if you have a 3 pin add header and it's standard mode is something like Rainbow it should take the motherboards lead. I would also think that with the 5v addressable RGB control would work as an add header is an add header and whatever is programmed to show would probably do it.
I know contradicting. but after owning it I think I could control it with the add header. It shows up as RGB Strip in Aura anyway.. very generic.
InWin 909 Silver RGB build
i9-10900k
ROG Maximus XII Apex
ROG Matrix 2080 ti
Gskill Trident Royal 4400 16g
Everything overclocked and love it.
ROG Awesomeness !!!!
