Results 1 to 6 of 6
    ROG Enthusiast Array Tonyboj PC Specs
    Tonyboj PC Specs
    MotherboardAsus Rog Rampage Extreme Omega
    ProcessorIntel Core X 10980XE
    Memory (part number)128GB G.Skill TridentZ 3000 MHz (F4-3000C14Q2-128GTZR)
    Graphics Card #1EVGA GeForce RTX 3090 FTW3 Ultra/Asus RTX 3090 EKWB
    Graphics Card #2Intel Optane 900p 480 GB PCIe
    Graphics Card #3Asus Hyper M.2 with 4 Intel Optane 900p (DATA)
    Sound CardSONY TA-ZH1ES
    MonitorAsus ProArt PA34V 100hz 3440x1440
    Storage #1Intel 905p 480GB U.2 (total Optane 2TB)
    Storage #22TB Optane; 3TB M.2; 4 TB SSD; 26 TB HDD
    CPU CoolerEKWB Custom Water Cooling: Dual-Pump; 480 XE-480XE-360XE-420PE
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX1600i
    Keyboard Logitech G915; Logitech Craft
    Mouse Asus Rog Chakram
    Headset Sony MDR-Z1R with RØDE NT MINI microphone
    Mouse Pad Nitro Concepts Full Desk
    Headset/Speakers B&O Play H95
    OS Windows 10 Pro for Workstations
    Network RouterNETGEAR ORBI PRO
    Accessory #1 Wacom Intuos Pro
    Tonyboj's Avatar
    Dec 2018
    27
    9990xe - is it even possible to manage cooling and power?
    No answers on my previous thread so I'll be frank. I was about to purchase this overpriced strange specimen for my business but did a mistake when ordering and purchased it personally. A part of me is thinking - this might be fun, another part is thinking - this is too expensive and too difficult to keep cool.
    So, for those of you have have good experience with OCing SkylakeX HCC CPUs, I have two questions...
    1. Would water be enough to cool 14 cores running up to 1.49 Volts (no typo)?
    I was thinking of putting together three radiators with one or two pump/res only for CPU, and push/pull with somewhat silent fans.
    My current board (Rampage VI Extreme) is likely not capable of running this since the powerdraw is basically 500-600W for the CPU. It could certainly be a ****ty driver since I'm not 100% what to change to give my current CPU enough power during overclocking. It basically restarts when I bench too power hungry stuff.
    2. So, if I invest in the Rampage VI Extreme Omega, will my problems be solved or do I still need some magic settings in bios to give my current chip (while OCing) or this new CPU a stable working environment?
    Immensely happy if some you with experience give any advice. There is also the option to just send it back without using it.
    ROG Guru: Yellow Belt Array x-rated PC Specs
    x-rated PC Specs
    MotherboardAsus ROG Maximus XI Formula - Intel Z390
    ProcessorIntel Core i9-9900K @ 5 GHz
    Memory (part number)G.Skill Trident Z F4-3600C16D-16GTZR - 4x 8 GB, 4 GHz, 17-17-17-37
    Graphics Card #1Nvidia GeForce RTX 2080 Ti FE - 2,1/15,6 GHz
    Sound CardCreative Sound Blaster X-Fi Titanium HD
    MonitorDell UP2715K - 5120x2880, AH-IPS, 10bit
    Storage #1Sabrent Rocket - 4 TB, 3 GB/s
    Storage #2SanDisk Extreme Portable SSD V2 - 2 TB, 1 GB/s
    CaseFractal Design Define R6 Blackout TG
    Power SupplyCorsair HX1000i - 1 KW, 83 A, 80Plus Platinum
    Keyboard Logitech G810 Orion Spectrum
    Mouse Logitech G403 Prodigy Wired
    Headset Sennheiser HD 660 S
    Mouse Pad Razer Manticor
    OS Windows 11 Pro
    Network RouterHuawei HG8245H @ 1 Gb/s FTTH GPON
    Accessory #1 EKWB Velocity + Vector
    Accessory #2 EKWB XRES 140 Revo D5 PWM + 2x CoolStream XE 360
    Accessory #3 6x Noiseblocker NB-eLoop Fan B12-PS
    x-rated's Avatar
    Aug 2015
    11
    203
    for 14 cores @ 5 GHz is some great chiller the only possible solution
    avx2 and 3 can produce a lot of heat, there is no chance to cool this with some standard radiators
    Tonyboj PC Specs
    Tonyboj's Avatar
    Dec 2018
    27
    Quote Originally Posted by x-rated View Post
    Since I don’t know what a chiller is I assume it is not suitable when my home office is in the corner of our living room
    From stock the AVX loads were set on 3.9 and 3.7 I think. Is it still not feasible with custom water?
    x-rated PC Specs
    OS Windows 11 Pro
    x-rated's Avatar
    Aug 2015
    11
    203
    chiller is something like little fridge, radiator, just another case, which can cool the liquid to almost 0°C
    for example http://www.aquariumonlinesupplies.co...00l-white.html
    im not sure if there is some default offset for AVX load, but according to wikichip this CPU can run all cores at 5 GHz by default
    if thermal and power limits are exceeded, it will lower the frequency
    Tonyboj PC Specs
    Tonyboj's Avatar
    Dec 2018
    27
    Yeah, all cores can boost to 5.0ghz, I think 2 of them to 5.1Ghz. Avx-512 is by default 3700 mhz, and avx 3900.
    What is the problem if a CPU instantly reboots the computer when starting any kind of benchmark (XTU, Cinebench etc)? Windows usage is fine.
    What are the basic settings on Asus R6E to give the CPU the option to use more power? (I have tried setting phases to Extreme, something to 200%, Input Voltage to 2.1...)
    ROG Guru: Yellow Belt Array feedmeink PC Specs
    feedmeink PC Specs
    MotherboardX299 Rampage vi extreme
    ProcessorI9 7980xe
    Memory (part number)Corsair vengeance lpx 4000mhz 32gb (2x16gb)
    Graphics Card #1Ek waterblock vega 56
    Storage #1Samsung 970pro 1tb m.2
    CPU CoolerEk full monoblock
    CaseLian li pc-011 dynamic
    Power SupplyEvga 1200 watt platinum
    OS Windows 10
    Jul 2018
    69
    187
    Sent you a private message. I would not set voltage that high. Try and keep voltages below 1.2. I recomend 1.12 to mitigate cooling. I have never taken this chip over 1.35. 1.35 running daily is horrible for your processor. But I overkill on cooling with 3 thick 360mm rads.
Tags for this Thread
