Results 1 to 6 of 6
07-07-2019 02:25 PM #1
Eguun PC Specs Motherboard Asus ROG MAXIMUS XI EXTREME (Z390 EATX) Processor Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz Memory (part number) Corsair DOMINATOR® PLATINUM 16GB (2 x 8GB) DDR4 4000MHz (SKU: CMD16GX4M2E4000C19 ver 4.31) Graphics Card #1 MSI - NVIDIA GeForce RTX 2080 8 GB GAMING X TRIO Storage #1 Samsung SSD 970 PRO 512GB Storage #2 Samsung SSD 960 PRO 512GB CPU Cooler Noctua NH-D15 Case Cooler Master MasterCase H500M Power Supply SeaSonic - PRIME Ultra Titanium 650 W 80+ Titanium Mouse SteelSeries Rival 500 Headset ROG Centurion true 7.1 OS Windows 10 Pro 64bits
- Join Date
- Feb 2018
- Reputation
- 10
- Posts
- 11
Maximus XI extreme: XMP issue on BIOS ver 1105
Dear all,
I am having issues with XMP profiles on the latest BIOS version 1105 on my ROG Maximus Extreme.
Previous version 1005 (and below) were OK.
When enabling XMP (1 or 2), my RAM OC settings are properly detected, and I can save settings OK.
But after having saved the settings, during each boot before POST, the motherboard powerdown itself and power back up. It does it ~4 times on cold boot (ie: when power is switched off and outlet disconnected for more than 10 seconds). Only after these 4 cycles do I get a proper POST with the "press F2 to enter bios settings".
It's as if the motherboard has issue POSTing properly once XMP is enabled.
When entering bios after these poweron/poweroff cycles at boot, I discover that some BIOS settings are changed from auto to fixed values (such as CPU VCCIO).
Sometimes even my XMP values are overriden (such as the frequency, for a lower setting).
I even tried to manually set in the bios the RAM parameters of the XMP profile (and disable XMP, since I had already punched-in the proper settings in the bios), but the behavior of several poweron/off cycles at boot remains.
I'm a bit puzzled on this behavior, that only occurred a few weeks ago when upgrading to the 1105 BIOS, which claims to feature "Improved DRAM compatibility" in its changelog.
As all was working very fine before the Bios software upgrade, I'm not convinced this is an hardware issue.
Is anyone else also experiencing these issues?
What would be your recommendation?
Full config details:
Processor: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
Motherboard: Asus ROG MAXIMUS XI EXTREME / Bios version 1105 (latest at time of writing post)
Memory: Corsair DDR4 2x8GB (SKU: CMD16GX4M2E4000C19)
Graphic card: NVIDIA GeForce RTX 2080 / driver version 430.86 (latest at time of writing post)
OS: Windows 10 Pro 64bits / version 1903 (latest at time of writing post)
Kind RegardsLast edited by Eguun; 07-08-2019 at 05:58 AM.
07-10-2019 09:37 AM #2
- Join Date
- Feb 2018
- Reputation
- 10
- Posts
- 11
105 view and no replies.
I'm feeling a bit alone here.
Noone here experiencing XMP issue with bios 1105 on this motherboard?
Thanks
07-10-2019 02:34 PM #3
Enderwiggin03 PC Specs Motherboard ROG STRIX Z390-E Gaming Processor Intel Core i9 9900k @ 5.1Ghz on all 8 cores 1.36v Memory (part number) F4-4266C19D-16GTZR @ 4000Mhz CL16-17-17-35 1.45v Graphics Card #1 EVGA RTX 2070 XC Ultra Sound Card Creative Sound Blaster X AE-5 Monitor ASUS VG248QE Storage #1 Samsung 970 Evo 500GB m.2 Storage #2 Samsung 860 Evo 1TB SATA CPU Cooler EVGA CLC280 with 4x NF-A14 iPPC-3000 PWM (push/pull)fans Case Fractal Design R6 Power Supply EVGA G3 1000w Keyboard Logitech G513 Carbon Mouse Logitech G703 Mouse Pad Logitech Poweplay OS Windows 10 Home x64
- Join Date
- Nov 2018
- Reputation
- 10
- Posts
- 189
I don't know your board, but is your ram on the QVL? If not, you might need to use manual timings, especially VCCIO and VCCSA, usually auto is way too high.
07-11-2019 03:00 AM #4
- Join Date
- Nov 2018
- Reputation
- 10
- Posts
- 16
My ROG Maximus XI Code was running just fine until loading 1105, after updating my system lost 20-25% performasnce, instability and numerious reboots to the point I decided to roll back the BIOS.
I then found out all my one usable BIOS files were not recognized by EZ Flash, I ended up rolling back the BIOS using the motherboards BIOS slot on the back of the board. I wasted a lot of hours getting 1105 off my machine, in my opinion its a faulty BIOS! Others are having similar issues.
Take a read starting at page 23 of this thread...
https://rog.asus.com/forum/showthrea...ighlight=MarvCLast edited by MarvC; 07-11-2019 at 03:02 AM.
07-11-2019 06:50 AM #5
- Join Date
- Feb 2018
- Reputation
- 10
- Posts
- 11
Many thanks for your replies,
@Enderwiggin03: yes I can find my RAM SKU on the QVL. That RAM is listed under version 4.31, which is the same version I have installed. Also as presented in first post, punching numbers does not change the behavior.
@MarvC: many thanks, this is of great value. I don't feel as alone now, facing issues on upgrading towards that specific 1105 BIOS version.
Having read what you linked, I believe your path to downgrade BIOS version and skip bugged 1105 is most reasonable.
CheersLast edited by Eguun; 07-11-2019 at 04:31 PM.
07-11-2019 04:31 PM #6
- Join Date
- Feb 2018
- Reputation
- 10
- Posts
- 11
@MarvC: thanks (again) for the tip.
I rolled back to 1005, all is OK.
I also raised a ticket with the support to notify about the misbehavior of XMP with that version of the BIOS.
They were aware of some users having some issue, but not that one specifically.
I provided them with the exact specs so hopefully they would be able to replicate and troubleshoot
Cheers
