AGESA 1.0.0.3 when for Asus B450-F
raven77uk
I want to purchase a 3600 but not before I get proper bios support for it.
5 REPLIES 5
Gamil
ASUS has been dead silent, so as far as I can tell right now: Never.
DMAN999
The ROG Strix B450-F Gaming has supported the Ryzen 5 3600 since BIOS 2301.
https://www.asus.com/us/Motherboards/ROG-STRIX-B450-F-GAMING/HelpDesk_CPU/
The Newest versions is now 2501:
https://www.asus.com/us/Motherboards/ROG-STRIX-B450-F-GAMING/HelpDesk_BIOS/
Yes however the AGESA updates are essential for certain fixes and the newer bios is lacking those - Asus is being seriously lax at the moment with the communications and updates to the point where I will probably be ditching them for another vendor, I'm far from impressed.
I would like to know this as well, i'm personally not having that many issues with my 3700x, all the high voltages can be solved using ryzen master.
But my problem with this board is that it freezes at the rog logo when i install an nvme drive in any of the available slots, the nvme drive does work, i've tested it on another asus board.
Currently these bios are unusable. If I change any setting at all from stock it fails to post and only clearing CMOS can get me back into bios then I need a full reinstall of the bios before I can get into windows again.
