Results 1 to 4 of 4
    ROG Member Array
    Sep 2015
    5
    X370 strix and ryzen 3
    I was wondering if anyone is planning to try the 3900 on this board, or would it just be a bad idea. I am currently running a 1700 overclocked to 3800mgz with a Kraken cooler. I really don't want to get a new motherboard now, I would rather upgrade in steps and use the board and memory i currently have as long as i can.
    Thanks
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    294
    7,410
    According to AMD this generation should work with x370 after a BIOS update. So you would need to check to make sure the latest BIOS supports 3rd gen. If not then you need to wait.
    I've also heard that newer boards might improve memory overclocking with better traces, etc. So if you are having memory issues you might end up needing to upgrade the board as well. No harm starting with the CPU though and worrying about the board later.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Member Array
    Sep 2015
    5
    Thanks, I have installed the latest bios, 5801, however there is nothing stating specifically what latest cpu;s are included for support. I am not having any memory issues running flare x at 3200 currently. I have read that there will be virtually no performance differences with the x470 and x 570 boards, but no information on x370 board. I would like to think I would get a boost but not sure if I will be loosing too much of what the new processor has to offer. I will give it some time I am sure someone will eventually experiment with it.
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    294
    7,410
    Firmware updates almost never list specific product compatibility updates. They're usually along the lines of "compatibility for latest generation of CPUs" or something equally vague. If you're lucky it will say 3000 series but wouldn't list specific models. You could also check the compatibility list but I'm not sure if those always get updated when a firmware update goes out.
