Results 1 to 2 of 2
    New ROGer Array Lucyisback's Avatar
    Jul 2019
    1
    Exclamation Battery not charging while gaming
    Whenever i play games it says plugged in ,not charging..... Due to this the game lags... As soon as i quit the game it starts charging again...
    Methods i already tried:-
    1. Battery callibration.
    2. Hard reset
    3. Updating ACPI driver
    4. Updating BIOS
    The temperatures are pretty fine so no heating issue(60-70 degree celcius)
    When i perform stress test for cpu the problem is not there but whenever cpu as well as gpu is used problem arises like benchmark tests and gaming...
    Need Help..
    ROG Guru: Orange Belt Array FULLMETALJACKET7's Avatar
    Mar 2018
    45
    337
    That's normal and the "lag" has nothing do to with the battery charging state.
