Results 1 to 1 of 1
    ROG Guru: White Belt Array FalloutBoy PC Specs
    FalloutBoy PC Specs
    Laptop (Model)G751JY-T7042H
    MotherboardROG Zenith Extreme Alpha
    ProcessorAMD 2950X
    Memory (part number)Corsair CMW64GX4M4C3200C16W
    Graphics Card #1Aorus GTX 1080 Ti Extreme 11Gb
    Sound CardInbuilt
    MonitorViewsonic XG-2703-GS
    Storage #1Samsung 960 EVO 1 Tb
    Storage #2Raid 6 Array 8 x 4 Tb SAS III on a 9361-8i
    CPU CoolerNoctua NH-U14S TR4 Edition with two AF15s
    CaseXigmatek Elysium Super Tower
    Power SupplySilverstone Strider ST-1500
    Keyboard Hyper X Alloy Elite RGB
    Mouse Razor Chroma Deathadder
    Headset Hyper X Revolver S
    Mouse Pad Playmax
    Headset/Speakers Creative Labs 2.1
    OS Windows 10 Pro 64 Bit 1903
    Network RouterFritzbox 7490
    Jan 2013
    95
    Query RE Rog Zenith Extreme onboard OLED display
    So I don't have to rip my system apart.. yet.
    On page 1-26 Item 16 Shows an OLED header, I am assuming that this is an expansion header for another OLED display so that you can have one at the front of the case if you want to.
    If that is a correct assumption:
    What is the ASUS part number for the additional OLED? , Does the OLED cable supplied with that unit have various lengths?
    If it is an incorrect assumption:
    If the header is used for the existing display and I want to move it to the front of the case does anyone know ( again without me ripping apart my system ) how long the OLED cable supplied is?
    Thanks in advance.
    I truly believe that there are people on this planet who should voluntarily remove them selves from the gene pool.
    Maximus IV Extreme Z/16G/2600K, Rampage V Extreme Edition 10/32G/6900K, G751JY-T7042H
    Zenith Extreme Alpha/64G/2950x , X399 Prime A/32G/1900X
    Power Mad Mu ha ha ha
Tags for this Thread
