Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 35
    ROG Enthusiast Array pegadroid PC Specs
    pegadroid PC Specs
    MotherboardASUS MAXIMUS VII HERO
    ProcessorI7 4790K
    Memory (part number)CMD8GX3M2B2133C9
    Graphics Card #1ASUS GTX 780 TI DCII OC
    MonitorLG D2343P
    Storage #1SSD SAMSUNG EVO 250
    Storage #2WD BLACK 1TB, WD BLUE 1TB, WD BLUE 1TB
    CPU CoolerNZXT X61
    CaseNZXT PHANTOM 240
    Power SupplySEASONIC P760
    Keyboard G110
    Mouse G500s
    Headset AKG GHS1
    OS Windows 8.1 Pro
    Network RouterTP-Link TD-W8961N
    pegadroid's Avatar
    Feb 2014
    36
    44
    HELP RAM TIMING 3000MHz
    i7 6700k 4.6GHz 1.350V
    ASUS Z170 DELUXE
    32GB 4X8GB CMR32GX4M4C3466C16 run with 3000MHz 1.300v 15-16-16-39 2T run Stressapp test for 1 hour with no error
    this timing too loose?
    ROG Guru: Platinum Belt Array Rockford PC Specs
    Rockford PC Specs
    MotherboardAsus ROG Strix B450-I
    ProcessorRyzen 2700X
    Memory (part number)Crucial Ballistix Tactical 2X4GB
    Graphics Card #1ASUS GTX 970 DC2OC BLACK
    Storage #1Kingston HyperX 3K MLC 120GB
    Storage #2WD VelociRaptor 150GB
    CPU CoolerRyzen Wraith Prism
    CaseBench
    Power SupplyEVGA Supernova G2 650W
    Accessory #1 Wife
    Rockford's Avatar
    Jan 2012
    218
    6,267
    Its like saying, is the earth too round?
    that's normal timings for memory kits in that XMP frequency range
    if it feels good for you, and everything is working great.... go for it
    its always going to be people in here claming that 9-27-4-21-0T would be better, so
    listen to your heart not to others, good luck
    pegadroid PC Specs
    ProcessorI7 4790K
    MonitorLG D2343P
    CPU CoolerNZXT X61
    Keyboard G110
    Mouse G500s
    Headset AKG GHS1
    OS Windows 8.1 Pro
    pegadroid's Avatar
    Feb 2014
    36
    44
    Quote Originally Posted by Rockford View Post
    listen to your heart not to others.......
    i test now 3000 14-14-14-35 1.35.
    Rockford PC Specs
    CaseBench
    Accessory #1 Wife
    Rockford's Avatar
    Jan 2012
    218
    6,267
    Dont forget to save a default profile in bios with your stable settings, so you have a quick and safe return ))
    ROG Guru: Yellow Belt Array feedmeink PC Specs
    feedmeink PC Specs
    MotherboardX299 Rampage vi extreme
    ProcessorI9 7980xe
    Memory (part number)Corsair vengeance lpx 4000mhz 32gb (2x16gb)
    Graphics Card #1Ek waterblock vega 56
    Storage #1Samsung 970pro 1tb m.2
    CPU CoolerEk full monoblock
    CaseLian li pc-011 dynamic
    Power SupplyEvga 1200 watt platinum
    OS Windows 10
    Jul 2018
    69
    187
    You should be able to do 1t timings. I would keep your old setting but put to 1t and see how it goes. If it doesnt pass try bumping voltage to 1.38. Have you adjusted any secondary timings?
    pegadroid PC Specs
    ProcessorI7 4790K
    MonitorLG D2343P
    CPU CoolerNZXT X61
    Keyboard G110
    Mouse G500s
    Headset AKG GHS1
    OS Windows 8.1 Pro
    pegadroid's Avatar
    Feb 2014
    36
    44
    Quote Originally Posted by feedmeink View Post
    Thank you for responding. I am very happy
    i try :
    3000 15-15-15-39 1T 1,390v cant boot.
    3000 15-15-15-39 1T 1,400v cant boot.
    3000 16-18-18-36 1T 1,400v cant boot.
    I only change the primary timings,because it doesn't understand for the 2nd timing
    what else should I do?
    wi 2T i can run 3000 14-15-15-35 1.300v.
    with 1T will it be better?
  7. #7
    feedmeink PC Specs
    ProcessorI9 7980xe
    OS Windows 10
    Jul 2018
    69
    187
    1t is faster but realistically you wont see a large difference. It might not work due to the processor or some odd secondary timings that the board sets on it's own. If you aren't familiar with secondary timings, might as well leave at current stable settings.
  8. #8
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Hi pegadroid
    In the bios on the AI Tweaker page try setting:
    Dram Frequency - 3000MHz
    Dram voltage 1.40v - 1.45v
    CPU VCCIO voltage - 1.25v
    CPU System Agent voltage - 1.25v
    Primary timings: 15-15-15-35-2T
    If it boots and is stable try 1T, it should be able to do it.
    I have the Maximus IX code and 7700k, with G.Skill Trident Z I can boot at 4000MHz with 15-15-15-36-2T timings but is not fully stable, have settled on 4000MHz 16-16-16-39-2T.
    I have Dram voltage at 1.55v, these are Samsung B-Die which can handle up to 1.80v.
    CPU System Agent voltage = VCCSA - 1.320v
    CPU VCCIO voltage - 1.31v
  9. #9
    pegadroid PC Specs
    ProcessorI7 4790K
    MonitorLG D2343P
    CPU CoolerNZXT X61
    Keyboard G110
    Mouse G500s
    Headset AKG GHS1
    OS Windows 8.1 Pro
    pegadroid's Avatar
    Feb 2014
    36
    44
    how to set secondary timing? can you guide me? i want to try 1N
    Quote Originally Posted by Nate152 View Post
    Hi pegadroid
    I have the Maximus IX code and 7700k, with G.Skill Trident Z I can boot at 4000MHz with 15-15-15-36-2T timings but is not fully stable, have settled on 4000MHz 19-19-19-39-2T.
    i can run
    3000 14-15-15-35 2N 1.3000
    when change to 1T as recommended by you cant boot.
    i use latest bios 3801
  10. #10
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,359
    All right
    I don't fool with the secondary timings, I let those all on auto and set only the primary timings and command rate.
    Try raising the Dram voltage to 1.40v, if it doesn't boot try Dram voltage at 1.45v.
    If that doesn't work set:
    Dram voltage 1.45v
    CPU VCCIO voltage - 1.275v
    CPU System Agent voltage - 1.30v
    Primary timings: 15-15-15-35-1T.
    1T as you can tell is putting more strain on the cpu's IMC so you either need to stick with 2T or up the voltages or loosen timings to get 1T stable.
