Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 35 of 35
  1. #31
    ROG Enthusiast Array pegadroid PC Specs
    pegadroid PC Specs
    MotherboardASUS MAXIMUS VII HERO
    ProcessorI7 4790K
    Memory (part number)CMD8GX3M2B2133C9
    Graphics Card #1ASUS GTX 780 TI DCII OC
    MonitorLG D2343P
    Storage #1SSD SAMSUNG EVO 250
    Storage #2WD BLACK 1TB, WD BLUE 1TB, WD BLUE 1TB
    CPU CoolerNZXT X61
    CaseNZXT PHANTOM 240
    Power SupplySEASONIC P760
    Keyboard G110
    Mouse G500s
    Headset AKG GHS1
    OS Windows 8.1 Pro
    Network RouterTP-Link TD-W8961N
    pegadroid's Avatar
    Feb 2014
    36
    44
    Quote Originally Posted by Nate152 View Post
    That sounds ok as long as IO and SA voltages aren't too high, otherwise you'll have to loosen timings until you find stability.
    I asked at the Corsair forum, they suggest run at 3200 14-14-14-34 1.35V, I was very difficult to boot before at 3200 16-18-18-36. i try run 3200 14-14-14-34 1.35V, i can boots , but when run hci after 9% i have one error,
  2. #32
    ROG Guru: Yellow Belt Array feedmeink PC Specs
    feedmeink PC Specs
    MotherboardX299 Rampage vi extreme
    ProcessorI9 7980xe
    Memory (part number)Corsair vengeance lpx 4000mhz 32gb (2x16gb)
    Graphics Card #1Ek waterblock vega 56
    Storage #1Samsung 970pro 1tb m.2
    CPU CoolerEk full monoblock
    CaseLian li pc-011 dynamic
    Power SupplyEvga 1200 watt platinum
    OS Windows 10
    Jul 2018
    69
    187
    Try 14-15-15-36 at 3200.
  3. #33
    pegadroid PC Specs
    ProcessorI7 4790K
    MonitorLG D2343P
    CPU CoolerNZXT X61
    Keyboard G110
    Mouse G500s
    Headset AKG GHS1
    OS Windows 8.1 Pro
    pegadroid's Avatar
    Feb 2014
    36
    44
    Quote Originally Posted by feedmeink View Post
    200% pass hci at 15-15-15-35 2T, which better 14-15-15-36 or 15-15-15-35 ?
  4. #34
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,359
    14-15-15-36 would be the best timings.
  5. #35
    ROG Junior Member Array
    Jan 2016
    2
    run hci and getting error at 4%
    I tried running with 2 pieces and successfully running xmp 3466
    I am very confused, my Asus Z170 deluxe is bad?
