Results 1 to 6 of 6
    ROG Member Array gamersnom PC Specs
    gamersnom PC Specs
    Laptop (Model)Asus A451LN
    MotherboardROG MAXIMUS XI APEX
    ProcessorIntel Core i9 9900K
    Memory (part number)Trident Z RGB 2x16 GB F4-3200C14D-32GTZR @3800 17-17-17-32 2T
    Graphics Card #1ROG STRIX GTX 1080 Ti OC
    MonitorROG SWIFT PG279Q
    Storage #1ADATA SX8200 M.2 NVMe
    Storage #2Seagate Barracuda 2TB 7200 RPM
    CPU CoolerCorsair H100i RGB PLATINUM
    CaseCM MasterBox TD500
    Power SupplyCorsair RM850x
    Keyboard Corsair K70 RGB MK2
    Mouse Logitech G502 Hero
    Headset Logitech UE 6000
    Mouse Pad Sades Skadi XL
    Headset/Speakers Logitech G 633 Artemis Spectrum
    OS Windows 10 Pro x64
    gamersnom's Avatar
    Oct 2018
    22
    Ram capacity and overclocking capability?
    hello anybody...
    does ram capacity affects overclocking capability?
    i.e 16 gb kit vs 32 gb kit.. is it easier for IMC to handle lesser capacity?
    ROG Guru: Yellow Belt Array feedmeink PC Specs
    feedmeink PC Specs
    MotherboardX299 Rampage vi extreme
    ProcessorI9 7980xe
    Memory (part number)Corsair vengeance lpx 4000mhz 32gb (2x16gb)
    Graphics Card #1Ek waterblock vega 56
    Storage #1Samsung 970pro 1tb m.2
    CPU CoolerEk full monoblock
    CaseLian li pc-011 dynamic
    Power SupplyEvga 1200 watt platinum
    OS Windows 10
    Jul 2018
    69
    187
    It depends on motherboard and processor. If you want higher frequency and super tight timings you wanna go with 8gb sticks. The more sticks you have in the system the more limited it can become. There are select boards that run better with more sticks, but in the sense of an everyday system it will not really be noticable if you have to downclock frequency a bit. I have 2x16 4000 frequency sticks and had decent success at 3600 frequency. But I am running x299 and it is difficult and in some cases impossible to go beyond that frequency. Another factor is the type of sticks. Samsung bdie ect. Have a voltage goal that you are unwilling to go beyond. I refuse to go past 1.38 volts for dram for everyday use. But when I was just benchmarking I went to 1.42. The results weren't much better but if i had 8gb sticks it would probably help. Hope this helps. If you have any questions let me know. I've spent a good amount of time overclocking ram and fine tuning ram for everyday use
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,400
    Quote Originally Posted by gamersnom View Post
    Basically yes...as always it depends on the actual CPU sample but in general less ram and lower frequency is easier to run....
    ROG Guru: Brown Belt Array NemesisChild PC Specs
    MotherboardASUS Maximus X Hero (WI-FI AC)
    ProcessorIntel i7 8700K
    Memory (part number)G.Skill F4-3600C16D-16GTZR
    Graphics Card #1Nvidia GTX 1070 Ti FE
    Graphics Card #2Nvidia GTX 1070 Ti FE
    MonitorASUS ROG Swift PG278Q
    Storage #1Samsung 970 PRO 512GB NVMe M.2
    Storage #2WD Black 2TB 7200 RPM 64MB Cache
    CPU CoolerNZXT Kraken X42
    CaseCooler Master HAF 932 Advanced
    Power SupplyEVGA SuperNova 1200 P2
    Keyboard Logitech G910 Orion Spark
    Mouse Logitech G703 Wireless
    Headset Logitech G Pro
    Mouse Pad SteelSeries
    OS Windows 10 Home x64 (UEFI)
    Network RouterLinksys WRT1900AC
    NemesisChild's Avatar
    Sep 2011
    89
    1,783
    The sweet spot is 3200MHz with CL14 timings.
    If you don't need 32GB, go with 2x8GB sticks. They are much easier to OC, even versus 2x16GB sticks.
    Intel i7 8700K@ 5.2GHz (Delidded)
    ASUS Maximus X Hero (Bios 1801)
    NZXT Kraken X42
    G.Skill TridentZ@ 4000MHz CL16 2x8GB
    SLI: 2x Nvidia GTX 1070 Ti FE@ 2025/2025MHz
    OS: Samsung 970 PRO 512GB NVMe M.2
    Storage: Samsung 960 EVO 500GB NVMe M.2
    Storage: 2x Samsung 850 EVO 500GB
    Storage: WD Black 7200 RPM 64MB Cache 2TB
    gamersnom PC Specs
    gamersnom's Avatar
    Oct 2018
    22
    Thanks guys for replying.... now i understand why . i got to crank up a bit IO/SA voltage with the 32 gb kit to get the speed and timings i desired while the 16 gb kit needs less...
    now i'm running my 32gb kit (f4-3200c14d-32gtzr) @4000 mhz 17-17-17-34 2T, 1.35 v. seems stable with 1.22 IO/SA voltage... do you guys think its safe for daily use?
    DIMM temps peak @46 C when gaming,. idle @30-32 C.. is that okay?
    thanks.
    Sep 2011
    89
    1,783
    thanks.
    Yes completely safe, nice job!
    NZXT Kraken X42
