07-15-2019 03:19 AM - last edited 3 weeks ago by ROGBot
07-15-2019 03:42 AM
07-15-2019 07:47 PM
07-16-2019 08:30 AM
shahbaz wrote:
hi..
I'm also looking to upgrade my ROG G750JM motherboard to the G750JZ model one.
However my stock motherboard comes with i74700 HQ processor ,
and what i'm looking for is i74860 HQ processor with the Nvidia 880M 8GB graphics. I need the correct MOtherboard part number for this JZ model. without which service centre cant place the order
07-16-2019 10:31 AM
navis995 wrote:
I don't advise you to buy JZ model if you have JM now. But if you have JZ just look for g750jz motherboard. Any will fit, even those with 4860HQ even though you had originally 4700HQ or 4710HQ.
Just make sure its the same JZ/JW, motherboard number does not matter but the seller will ask you anyway.
I know from personal experience because I changed my g750jz motherboard 4 times.
08-21-2019 10:20 AM
shahbaz wrote:
Thanks for the reply.
Any specific reason for not suggesting this upgrade? like compatibility or something?
