Results 1 to 3 of 3
    ROG Guru: White Belt Array
    Jul 2013
    97
    intel management engine (ime) question
    it is necessary with IME also the appropriate programs to install (approx. 80MB),
    or is sufficient if I only use the drivers (few MB).
    In this forum very often only the driver files are offered,
    but ASUS always offers only the big package (60-80MB)
    best regards TOM
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,385
    Hi Tom Tromboni
    I believe you are referring to the motherboard disc?
    After a windows 10 install, I only install the Realtek audio driver and update the graphics driver.
    Everything else is not needed but it's there if you want it.
    Jul 2013
    97
    A big thank you for the quick reply
