Help, rog g21cn huracan spare hdd cable
t0918
in the offical upgrade video 2:48
https://www.youtube.com/watch?v=KWXygDXoASs
the HDD cable inside this computer is black yellow red black,
but the mini 4 pins to sata power cables on ebay or aliexpress is either yellow black black red or red black black yellow
for example like these:
https://hardforum.com/threads/found-mini-4-pin-to-sata-power-cable.1943518/
https://usb.brando.com/4-pin-mini-plug-to-sata-power-cable-90-_p03471c32d15.html
https://www.dhgate.com/product/10pcs-lot-ph-2-0mm-4pin-small-type-to-15pin/420574678.html
so where can i buy the cable inside the G21CN?
Val_70
Hi. I have the same question. I bought one of the cables from EBay and it’s not working. Actually, when plugged in, it prevents the PC from powering up. Were you able to solve? If positive, please send me the link of the one you bought. Thanks
Blake1
Dear both,
Please kindly contact our service center.
The cable of this model is different form those on the market.
Sorry for the inconvenience caused.
Blake@ROG wrote:
Dear both,
I contacted the service center in Hong Kong but they told me that no cables are available for me.
I would appreciate if you could arrange that your HK service center is providing the cable to me.
