Results 1 to 6 of 6
07-18-2019 04:53 PM #1
- Join Date
- Dec 2017
- Reputation
- 17
- Posts
- 17
Errors with G.SKill TridentZ with XMP on R6E
I'm a bit confused with XMP on the R6E.
My R6E board with UEFI 1503 is on default settings. When i try to enable XMP, Memtest86 runs for about 5 minutes and then throwing errors.
Without XMP, running on 2133(?) Mhz, Memtest86 runs for about 3 hours without any problems.
XMP with 3200 Mhz should run on that X299 board, right?
Is there any problem with that UEFI version?
I dont want to upgrade to 1704 because it seems to be very unstable.
Specs
CPU: Intel Core i9-7900X (delidded)
Mainboard: Asus ROG Rampage VI Extreme (UEFI 1503)
RAM: G.SKill TridentZ RGB 64GB (F4-3200C14Q-64GTZR)
GPU: 2x EVGA GeForce GTX 1080 Ti K|NGP|N Hydro Copper
SSD 1: Samsung 960 Pro M.2 1TB
SSD 2: Samsung 850 PRO 2.5" 2TB
PSU: EVGA SuperNOVA 1600 T2
07-18-2019 06:17 PM #2
JuSiZ1 PC Specs Motherboard Rampage VI Extreme Omega Processor i9-10940X Memory (part number) G.skill F4-3600C16Q-32GTZ Graphics Card #1 EVGA RTX 3080Ti FTW3 Sound Card Creative soundblaster X7 Le Monitor PG27AQ Storage #1 Samsung 970pro 512Gb, Samsung 960 Pro 2Tb Storage #2 960pro 1Tb 2x850pro 512gb and 1x1Tb 950Pro 512gb usbstick CPU Cooler EK Supremacy evo x99 Case Diy case Power Supply Corsair Ax1200i Keyboard Logitech G19 Mouse Logitech G Headset Fostex TH-610 Mouse Pad ROG from china Headset/Speakers The Drop And Monitors speakers OS Win 10 Pro 64-bit Network Router Fritz Box 6490 Accessory #1 H2O cooling with 3x360 rads, dual ddc pumps,EK blocks, 2x Aquaero 6etc. Accessory #2 BD-RE
- Join Date
- Nov 2014
- Reputation
- 22
- Posts
- 100
Don't use xmp. Set all manually and vccsa, cache and vccio voltages maybe need some tweaking. And testing use karhusoft memtest or hcimemtest.
07-18-2019 07:13 PM #3
- Join Date
- Dec 2017
- Reputation
- 17
- Posts
- 17
Are there any orientation where to start with the values?
07-18-2019 09:01 PM #4
- Join Date
- Nov 2014
- Reputation
- 22
- Posts
- 100
On bios set memory to 3200mhz and main latencies 14-14-14-34- 2T vccsa 0.95 cache 1.1v vccio 1.06v memory voltages to 1.38v. Are you overclock processor allready?
07-18-2019 10:54 PM #5
- Join Date
- Dec 2017
- Reputation
- 17
- Posts
- 17
Ok i try. No, cpu still on stock. i want OC it too
07-20-2019 06:45 AM #6
LiveOrDie PC Specs Motherboard ASUS RAMPAGE VI EXTREME OMEGA Processor Intel Core i9 10980XE 4.6Ghz 1.12v WC Memory (part number) G.Skill Trident Z RGB F4-3000C14D 64GB Graphics Card #1 EVGA RTX 3080 XC3 ULTRA EK WB/BP Monitor LG 4k 43inch Storage #1 Samsung 960 Pro NVME 1TB Storage #2 Samsung 860 Evo 1TB x 3 CPU Cooler EK-Velocity , EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM Case Corsair Obsidian 500D SE ATX-E Modded Power Supply Cooler Master V 1300W Keyboard Logitech G910 Mouse Logitech G900 Headset Razer Tiamat 2.2 v2 OS Windows 11 Insider Preview Network Router NetGear
- Join Date
- Dec 2011
- Reputation
- 40
- Posts
- 1,675
