Results 1 to 2 of 2
    New ROGer Array
    Jul 2019
    2
    Exclamation Rog hero 2 gl504gm sound problem
    Hi!
    I have a problem with sound on my gl504gm
    Sound randomly become low, then it become normal.
    The sound floats from normal to quiet.
    Driver ver is 6.0.8750.1 date 09.07.2019
    PS using Win10, with latest update installed. I try 6.0.1.8639 from https://www.asus.com/ru/Laptops/ROG-...Desk_Download/, problem same.
    New ROGer Array
    Jul 2019
    2
    Problem solved
    I install ROG Aura programm, and sound work good
