GTX1080 Strix led strip change to default 5pin header
medyq
Hi guys, does gtx1080 Strix A8G 11gbps has 5 pin rgbw strip under cover/ Iam making a custom frontplate and cooling system and want to mount new one/different led strip instead original. I found on aliexpress fans from strix with 6 pins plug (!!!) like original, but cant find anything about leds.
Importatn: I dont want extract led from origonal place under radiator (original cooling will go to box without changes)- want install new one leds few cm lenght but dont know if 4pin rgb (mounted on 4 headers) will be possible or need 5 pin plug rgbw - or - why this leds have 5 pins?? . And what voltage is it? 12v?
Picture below81072
0 REPLIES 0
