Results 1 to 5 of 5
    ROG Guru: Black Belt Array Hopper64 PC Specs
    Hopper64 PC Specs
    MotherboardAsus R6EO Bios 0702
    Processori9 9900X @ 4.9 1.28V VCore
    Memory (part number)GSkill F4-3600C16Q2-64GTZR
    Graphics Card #1EVGA 2080 Ti Kingpin
    Sound CardCreative SB AE7
    MonitorAsus ROG PG349Q
    Storage #1Intel 905p M.2 360G
    CPU CoolerEKWB Velocity RGB and Revo XRes 140 D5
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX1600i
    Keyboard Asus Strix Flare
    Mouse Asus ROG Gladius II Origin
    OS Windows 10 64
    Hopper64's Avatar
    Nov 2012
    36
    2,082
    Bios 0702 R6EO breaks Aura and LiveDash
    0602 for R6EO worked well with the latest software, but 0702 breaks both applications. Went back to 0602 on bios 1 chip and everthing works as it should. Made a thread in the software section:
    https://rog.asus.com/forum/showthrea...a-and-livedash
    Hopper64 PC Specs
    OS Windows 10 64
    Hopper64's Avatar
    Nov 2012
    36
    2,082
    Anyone else notice the same thing?
    Hopper64 PC Specs
    OS Windows 10 64
    Hopper64's Avatar
    Nov 2012
    36
    2,082
    Installed Aura 1.07.71 which seems to have fixed the problem. Both applications are now working under 0702. I also reflashed the bios using the flashback method.
    ROG Enthusiast Array Aysberg PC Specs
    Aysberg PC Specs
    MotherboardASUS ROG RAMPAGE VI EXTREME
    ProcessorIntel Core i9-7980XE
    Memory (part number)4 x F4-3200C14-16GTZ
    Graphics Card #1ASUS ROG STRIX GTX 1080 Ti GAMING OC
    Sound CardCreative SB Zx
    Monitor1x LG 34GK950G / 2 x HP DreamColor Z27x
    Storage #12 x Samsung NVMe 970 EVO 2TB / Samsung NVMe 3 x 960 EVO 1TB
    Storage #24 x SanDisk SDSSDHII960G
    CPU Coolercuplex kryos NEXT
    CaseLianLi PC-A75X
    Power SupplyCorsair HX1200i
    Keyboard Corsair K95 RGB
    Mouse Roccat KONE XTD Optical
    Headset AKG K712 + ModMic 5
    OS Windows 10 Pro x64 1809
    Network RouterMikroTik CRS317-1G-16S+RM
    Accessory #1 Mellanox ConnectX-3
    Accessory #2 Asus Hyper M.2 X16 Card
    Nov 2013
    18
    60
    Flashed the BIOS and basic Aura and Livedash from the BIOS itself works (after booting I have RGB effects and CPU temperature in the dash). Never used the applications, so cannot confirm any problems there. So far everything else looks good.
    ROG Guru: Brown Belt Array LiveOrDie PC Specs
    LiveOrDie PC Specs
    MotherboardASUS RAMPAGE VI EXTREME OMEGA
    ProcessorIntel Core i9 7980XE Custom IHS @ 4.6Ghz 1.23v
    Memory (part number)G.Skill Trident Z RGB F4-3000C14D 64GB
    Graphics Card #1AORUS GeForce RTX™ 2080 Ti XTREME WATERFORCE WB 11G
    MonitorLG 4k 43inch
    Storage #1Samsung 960 Pro NVME 512gb
    Storage #2Samsung 850 Evo 1TB x 2
    CPU CoolerEK-Velocity , EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
    CaseCorsair Obsidian 500D SE ATX-E Modded
    Power SupplyCooler Master Vanguard Series 1000W
    Keyboard Logitech G910
    Mouse Logitech G900
    Headset Razer Tiamat 2.2 v2
    OS Windows 10 x64
    Network RouterNetGear
    LiveOrDie's Avatar
    Dec 2011
    41
    1,680
    0702 works fine here with Aura.
