Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    ROG Member Array
    Feb 2017
    7
    Trident Z Royal + X99 Strix
    when does this board get driver support for G Skill Trident z Royal, is X99 strix mobo already dead?
    ROG Member Array
    Feb 2017
    7
    is there any admin or expert of asus rog product?
    ROG Guru: Blue Belt Array mdzcpa PC Specs
    mdzcpa PC Specs
    MotherboardMaximus Hero XI
    Processor9900k @ 5.1Ghz All Core 1.315v AVX -2
    Memory (part number)Gskill GTZ 4133 C17 32GB (4x8GB)
    Graphics Card #1ROG Strix 2080 TI OC
    Sound CardOn Board
    MonitorROG PG348Q
    Storage #1Samsung 970 Pro M.2 512GB for OS & APPS
    Storage #2Samsung 970 Pro M.2 1TB for GAMES
    CPU CoolerROG Ryujin 360
    CasePhanteks Evolv X
    Power SupplySeasonic Prime 1000W Titanium
    Keyboard Corsair K70 LUX RGB
    Mouse Corsair M65 RGB
    Headset Corsaur VOID Pro
    Mouse Pad Corsair MM300 Wide Desk Mat
    OS WIN 10 Pro
    Network RouterLinksys VELOP
    Accessory #1 ROG 751JY Laptop for Moobile Gaming
    Accessory #2 Koolance EXC-800 Chiller
    Accessory #3 25+ years of overclocking
    Nov 2011
    80
    977
    What driver support are you looking for? Lighting Control can be downloaded from Gskill.
    ROG Member Array
    Feb 2017
    7
    Quote Originally Posted by mdzcpa View Post
    already do that , currently using v1.00.03 g skill software and lastest asus aura from asus website yet none of those are working
    ROG Member Array
    Feb 2017
    7
    and i already update the bios, should i rma my motherboard? kinda funny the g skill already announce support for trident z product to be run in x99 but this mobo refuse it and i also got faulty gpu , god i even dont know how does asus control their QC nowdays
    mdzcpa PC Specs
    Sound CardOn Board
    MonitorROG PG348Q
    OS WIN 10 Pro
    Nov 2011
    80
    977
    What Gskill part number do you have?
    I suggest you uninstall aura and the Gskill light control. Fresh install the Gskill Light Control again (only) and see if that runs the ram RGB. Aura can be buggy. Process of elimination.
    Other idea is to run Aura only.
    In either case, not a good idea to run both lighting programs together. Aura can control the ram as well.
  7. #7
    ROG Member Array
    Feb 2017
    7
    no option on aura to control ram RGB , and already do the same as ur advice (re install everything, trying one of them being installed separately) but nothing change still stuck on rainbow mode
    do u even have x99?
  8. #8
    ROG Guru: Orange Belt Array ThrashZone PC Specs
    ThrashZone PC Specs
    MotherboardASUS z490 maximus XII Apex 2nd x299 Rampage VI Apex
    Processori9-10900k & i9-9940x
    Memory (part number)Trident-Z 3600c16 2nd Trident-Z 3600C16 both Samsung B-Dies
    Graphics Card #1EVGA 1080ti FTW3 water block 2nd Titan Xp copper water block
    MonitorAOC G2460PG 24"G-Sync 144Hz & ASUS VG248QE 24" 144Hz
    Storage #12-Samsung 970 Evo Plus 500gb M.2 & 2.5" ssd's 850 pro's for os 850 evo for games
    Storage #22-LG Blu-Ray WH16NS40
    CPU Cooler2-240GTX with Heatkiller-4-Pro/ vrm water block Both&x299 2-280GTX 2-D5's before and after rads
    Case2- Corsair 450D with second floors for 240GTX & 280GTX rads enclosed and filtered on top
    Power SupplyEVGA 1000P2 2nd EVGA 1200P2
    Keyboard Logitech G910 Orion Spectrum 2nd Logitech G710+
    Mouse 2-Red dragon Perdition
    OS Win-7 & win-10 pro on both systems Win-7 everyday os
    Accessory #1 Optimus Foundation copper plexi 2nd Optimus SigV2
    Accessory #2 ModmyMods clear coolant
    Accessory #3 ModMyMods 3/8-5/8" clear soft tubing/ MORA 360 Pro x2
    ThrashZone's Avatar
    Oct 2017
    23
    389
    Not sure why you'd want it
    As said rgb stuff is uncontrollable but maybe that is the support you're wanting doubt that will ever happen seeing yes x99 is eol
    It just got another Beta bios update but doubt any others will but that was mostly just for Intel security issues not adding anything else likely.
    x99 is fine with other trident-z
    I use 3200c14 = 14-14-14-34 timings
    As long as tight timings are used I'm sure it will work on x99.
    Non rgb overclocks better usually anyway so is this a show or go rig
    https://benzhaomin.github.io/bdiefinder/
  9. #9
    mdzcpa PC Specs
    Sound CardOn Board
    MonitorROG PG348Q
    OS WIN 10 Pro
    Nov 2011
    80
    977
    Quote Originally Posted by goezra4 View Post
    do u even have x99?
    No, I do not have X99 anymore. However the Gskill website says the ram is X99 and Aura compatible and I have several PCs running the Gskill RGB through Aura here at the house. All three boards different chipsets and it works. GSkill also announced that their RGB works on X99 back in April 2017. Your answer is out there somewhere...the net is choc full of postings about troubleshooting the RGB on X99. Good luck.
  10. #10
    ROG Enthusiast Array
    Jun 2013
    42
    For some magical reason, the latest version of Aura is working and recognizes my gskill royal dram RGBS. didn't need to install gskill's software for it. This is on a fresh windows install. I had issues with it before on a fresh install, so Asus is to blame here for terrible software support. This kind of random working/not working is on them. I've tried all the arduous unintall/cleaning steps on a current install in the past and nothing worked correctly. My guess is there is random asus aura software living in your system still, but that is speculation. I can finally use fanman03's rgb sync software to sync it all with iCue.
    X299 Tuf Mk1
    tridentz royal 3200 cl14
Tags for this Thread
