Results 1 to 7 of 7
    New ROGer Array
    Jul 2019
    2
    GA502DU - No performing well
    Hi All.
    Im new to ASUS. I love this new laptop. Partiucularly the Vega graphics run AUTOCAD LT much better than the Nvidia card does (I appreciate its not intended for CAD tho).
    however, im having some issues with the laptop. Ive formatted now 4 times with differing ways of installing drivers, clean installs. Have the my Asus, ammo crate installed etc.
    Basically it will not run any games very well. I can run battlefield 1 in nvidia recommended settings of mostly high to ultra. But the laptop keeps stuttering every 15-20 seconds, for around 1- 2 seconds at a time. Its unplayable. The sound also stutters / stretches.
    Tried in low res mode as thought maybe too hot. Still the same problem.
    Ive also noticed intermideate pauses on the mouse pointed during normal use. There's no reported issues in windows etc and no driver errors.
    Any ideas appreciated.
    New ROGer Array
    Dec 2019
    3
    hi did you ever sort this?
    my new laptop has the exact same issue
    ROG Enthusiast Array edrickjk PC Specs
    edrickjk PC Specs
    MotherboardASUS ROG MAXIMUS XI EXTREME
    ProcessorIntel Core i9-9900K
    Memory (part number)F4-4266C19-8GTZKW 8gbx4
    Graphics Card #1ASUS ROG STRIX RTX 2080 Ti GAMING OC 11G
    MonitorAcer predator X34P
    Storage #1Samsung SSD 970 EVO Plus 500GB
    Storage #2WDC WDS512G1X0C-00ENX0
    CPU CoolerEK-Velocity
    CasePhantek Enthoo Luxe 2
    Power SupplyCorsair HX1000I
    Keyboard Razer blackwidow x chroma
    Mouse Razer mamba wireless
    Headset SteelSeries arctis pro wireless
    Mouse Pad Razer Goliathus Control Extended
    Headset/Speakers Razer nommo chroma
    OS window 10
    Network RouterAsus RT-AC-5300
    Jul 2018
    71
    Just check the previous post, you need to repaste it, Asus factory use the worse thermal paste know to human kind. They use a ungodly amount , get better quality paste and use 05mm thermal pad on the vrm .
    New ROGer Array
    Jul 2020
    1
    GA502DU Nvidia Issue
    Thanks in advance for any help provided.
    Hello,
    I recently bought Zephyrus G GU502DU_GA502DU. The BIOS is on GU502DU.302
    After a week when I tried playing GTA V, my laptop had BSoD. After powering up, I started having issue with my NVIDIA. Below is the DxDiag report. I did clean uninstall and tried reinstalling every version but my device manger shows code 43 error. Please review on my issue and let me know with any solution that could resolve.
    xDiag Notes
    Display Tab 1: No problems found.
    Display Tab 2: No problems found.
    Display Tab 3: There is a problem with NVIDIA GeForce GTX 1660 Ti with Max-Q Design device. For more information, search for 'graphics device driver error code 43'
    Sound Tab 1: No problems found.
    Input Tab: No problems found.
    Card name: NVIDIA GeForce GTX 1660 Ti with Max-Q Design
    Manufacturer: NVIDIA
    Chip type: Unknown
    DAC type: Unknown
    Device Type: n/a
    Device Key: Enum\PCI\VEN_10DE&DEV_2191&SUBSYS_18D11043&REV_A1
    Device Status: 01802400 [DN_HAS_PROBLEM|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_ NT_DRIVER]
    Device Problem Code: 0000002B [CM_PROB_FAILED_POST_START]
    Driver Problem Code: Unknown
    Display Memory: Unknown
    Dedicated Memory: n/a
    Shared Memory: n/a
    Current Mode: Unknown
    HDR Support: Unknown
    Display Topology: Unknown
    Display Color Space: Unknown
    Color Primaries: Unknown
    Display Luminance: Unknown
    Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\nva m.inf_amd64_8b75cbed4ebcac62\nvldumdx.dll,C:\WINDO WS\System32\DriverStore\FileRepository\nvam.inf_am d64_8b75cbed4ebcac62\nvldumdx.dll,C:\WINDOWS\Syste m32\DriverStore\FileRepository\nvam.inf_amd64_8b75 cbed4ebcac62\nvldumdx.dll,C:\WINDOWS\System32\Driv erStore\FileRepository\nvam.inf_amd64_8b75cbed4ebc ac62\nvldumdx.dll
    Driver File Version: 26.21.0014.4294 (English)
    Driver Version: 26.21.14.4294
    DDI Version: unknown
    Feature Levels: Unknown
    Driver Model: Unknown
    Graphics Preemption: Unknown
    Compute Preemption: Unknown
    Miracast: Unknown
    Detachable GPU: No
    Hybrid Graphics GPU: Unknown
    Power P-states: Unknown
    Virtualization: Not Supported
    Block List: Unknown
    Catalog Attributes: Universal:False Declarative:True
    Driver Attributes: Final Retail
    Driver Date/Size: 4/8/2020 5:45:00 AM, 963816 bytes
    WHQL Logo'd: Yes
    WHQL Date Stamp: Unknown
    Device Identifier: Unknown
    Vendor ID: Unknown
    Device ID: Unknown
    SubSys ID: Unknown
    Revision ID: Unknown
    Driver Strong Name: oem2.inf:0f066de339a33a0c:Section118:26.21.14.4294ci\ven_10de&dev_2191&subsys_18d11043
    Rank Of Driver: 00CF0001
    Video Accel: Unknown
    DXVA2 Modes: Unknown
    Deinterlace Caps: n/a
    D3D9 Overlay: Unknown
    DXVA-HD: Unknown
    DDraw Status: Enabled
    D3D Status: Not Available
    AGP Status: Enabled
    MPO MaxPlanes: Unknown
    MPO Caps: Unknown
    MPO Stretch: Unknown
    MPO Media Hints: Unknown
    MPO Formats: Unknown
    PanelFitter Caps: Unknown
    PanelFitter Stretch: Unknown
    Thank you
    Moderator Array
    Feb 2019
    13
    428
    Hello gigyalzen,
    Please kindly send your device to service center for further examination.
    New ROGer Array
    Jul 2020
    2
    I used to have frequent BSOD on my ASUS GA502DU laptop and I tried all sorts of system tweaks and fixes. People recommended that I update the BIOS to the latest version and I did all that. I eve went to the Windows 10 system registry to do some tweaking. Still, the RAM usage would constantly rise over time and that caused a lot of crashing and BSOD on my unit.
    However, back in my early years of being a laptop tech enthusiast I remembered that despite the fact that Windows 10 automatically makes updates on all drivers in a system as best it could, one should ALWAYS download all drivers from the manufacturers still. Also the order of driver installation matters as well.
    So, after the BIOS update, I decided to update the Chipset from ASUS website. Now, when I checked my ASUS Armory Crate I am glad to see my RAM getting back down when not busy. Memory leakage must have been caused because of not using the actual ASUS chipset driver for the motherboard. This solved my problem.
  7. #7
    Moderator Array
    Mar 2018
    19
    30
    Hi rippler7 ,
    Thank you for sharing your solution with others, and glad that our technical support on the website can solve your problem.
