Results 1 to 2 of 2
    ROG Guru: Yellow Belt Array
    Apr 2013
    17
    147
    Node Connection replaces Rog_Ext. struggling to create cable/connector
    I have a new Crosshair VIII Hero with a Node connection.
    I would like to use this connector to get my front base working. so as to acquire the cpu temps and fan speeds etc...
    Unfortunately I do not have extensive experience with cabling and although I have managed to repin the usb section of the rog_ext connector.
    I am dumbfounded by the Node connection, as it is 2ml's smaller than a normal usb connector.
    is there a name for the size of these connections, I have tried to google this with no success. as I have such little knowledge on this subject.
    if I place the cables directly into the Node connection, I am likely to short it out. So my only option atm is to aquire a single wire connection for each cable and
    then to sand down these plastic connections untill they fit into the node socket. creating a smaller connector.
    I have seen pics of others who have managed to connect with a smaller connection so I know they exist.
    Can anyone give me a heads up or point me in the right direction. Ty
    AsusCrosshairHeroVIII - 5950X
    32Gb G.Skill RGB Trident 16gb3466Mhz B-Die + 16gb4266Mhz B-Die
    Asus Tuf RTX3090
    1TbSamsung960EVO M.2 1TbSamsung850EVO SSD Seagate2TB/3Tb CorsairForceGt 64gb
    Seasonic Focus1000w 80+ Gold
    Thermaltake Core X71 Tempered glass side panal
    Apr 2013
    17
    147
    Still have this issue in 2021!!!!
    Asus Tuf RTX3090
