Hello,
A couple of days ago i got my pc upgrade, which was ROG CROSSHAIR VII HERO and Ryzen 9 3900x, guys at store already updated bios so it supports new ryzen.
I installed os, played it in for a little bit and then i went to bios to set time, ram frequency and set cpu overclock things to auto, and i remember setting some sort of boost to enabled.
When i was scooping around bios, i found this tool called Asus ez tune, i gave it try, then it restarted, i let it be for like 5 mins, then i came back and nothing.
Then i tried using safe boot, retry button and clear cmos button, nothing, all the rgb starts shining but on monitor there's nothing, not even bios screen that says F2 or Delete to enter bios. (I got 2 codes E8 or 8E (can't remember which one) and after a while - 0C on that little screen and vga light shines white.)
I already gave my pc back to store where i got the it so they can reflash bios with older native cpu, because they said that bios somehow reseted itself before the support update for ryzen 9.
But my question is, that latest bios update on asus support site that is 6 days old now, does it support the new ryzen 9 ?
And also does this ever happened to someone when using asus ez tune, and possible fix ?
Thanks for help.
Lukas
