Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    ROG Enthusiast Array
    Aug 2018
    32
    So far a Smooth Experience 3700X on CrossHair VI Extreme
    I have Asus Crosshair VI Extreme working fine without any issues with the 1800X the cpu I used before upgrade to Ryzen 3000
    For upgrade I put the latest bios via flashback , rename the file with the renamer tool that is inside the file . Just exchange the cpu with 3700x , and populate all 4 memory slots with Crucial Ballixtic Memory Kit 4x 8GB at 3200mhz , press power and took less than one minute to enter to Bios, just change some setting on Bios to drop the cpu temps and ryze the memory frecuency at 3600MHZ . got good temps HW show at full load about 4.2 to 4.3ghz and good scores on CINEBENCH R20
ID:	81142Click image for larger version.
ID:	81143Click image for larger version.
ID:	81144Click image for larger version.
ID:	81145Click image for larger version.
ID:	81146Click image for larger version.
    ROG Guru: Brown Belt Array gupsterg PC Specs
    gupsterg PC Specs
    MotherboardAsus Maximus VII Ranger
    Processori5 4690K
    Memory (part number)HyperX Savage 2400MHz 16GB
    Graphics Card #1Sapphire R9 Fury X (1145/545 Custom ROM)
    MonitorAsus MG279Q
    Storage #1Samsung 840 Evo 250GB
    Storage #2HGST 2TB
    CPU CoolerThermalRight Archon SB-E X2
    CaseSilverstone Temjin 06
    Power SupplyCooler Master V850
    Headset/Speakers HyperX Cloud
    OS Win 7 Pro x64 / Win 10 Pro x64
    gupsterg's Avatar
    Feb 2015
    103
    1,017
    Nice .
    Intel Defector AMD Rebel
    TR 1950X - Custom WC - Asus Zenith Extreme Alpha - G.Skill Trident Z 3400MHz C14 QC - RX VEGA 64
    R5 3600 - Custom WC - Asus Crosshair VII Hero Wifi - G.Skill Ripjaws V 3800MHz C16 - Sapphire HD 5850 Toxic
    24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
    Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
    New ROGer Array
    Sep 2019
    1
    Some problem wanna help
    Quote Originally Posted by roco_smith View Post
    Hi, I am from Hong Kong
    Would you share your setting of BIOS?
    Coz I got the same equipment and I have some problems of setting and something like bug~
    On the other hand, did you have the problem like the end of video. Delay booting in X370 ROG Crosshair VI Extreme with 3700X
    ROG Enthusiast Array Sigtran PC Specs
    Sigtran PC Specs
    MotherboardAsus Crosshair VI Hero
    ProcessorRyzen 9 3900x
    Memory (part number)F4-3200C14D-16GVK @ 3466MHz
    Graphics Card #1Gigabyte GTX1080ti Gaming OC
    Monitor24" Dell Ultrasharp 2407WFP-HC
    Storage #1Samsung 960 EVO 500GB
    Storage #2Samsung 860 EVO 1TB
    CPU CoolerNoctua NH-D14
    CaseCoolerMaster 690
    Power SupplyCorsair HX1000i
    Keyboard Dell SK-8115
    Mouse Logitech M705
    Headset/Speakers Logitech X-540
    OS Win10 X64 Home
    Network RouterAC2600
    Accessory #1 Logitech C930e webcam
    Sigtran's Avatar
    Sep 2017
    28
    67
    Consider yourself lucky, CH6 rarely works fully stable with 4ch memory @3600MHz.
    CH7 and CH8 work fine (if memory is capable of course) since their board traces are different topology allowing higher memory frequencies.
    New ROGer Array
    Aug 2019
    11
    Quote Originally Posted by Sigtran View Post
    c6h has t topology i think the c8h had daisy chain
    t topology is sposed to be better for 4dimm
    Aug 2018
    32
    Well just upgrade to the 3900X and very please to the performance of the CH6 Extreme , definiteClick image for larger version.
ID:	82752 this board can handle the 3950 without any issue
  7. #7
    ROG Guru: Orange Belt Array AQUASTEVAE PC Specs
    AQUASTEVAE PC Specs
    MotherboardROG Crosshair VI EXTREME
    ProcessorRyzen 7 1700
    Memory (part number)32gb GSkill FlareX 3200mhzC14
    Graphics Card #1GIGABYTE 1080 ti EXTREME
    Monitor55" UHDR 4K TV
    Storage #1SAMSUNG 960 EVO M.2 NVME 500GB
    Storage #2SAMSUNG 951 M.2 PCIe AHCI 512GB
    CPU CoolerNZXT kRAKEN X62
    CaseCOOLERMASTER MAKER 5T
    Power SupplyCORSAIR RM850X
    Keyboard LOGITECH K850 WIRELESS BACKLIT
    Mouse LOGITECH M570 TRACKBALL WIRELESS
    Headset 2.4GHz Wireless Headphones with Detachable Mic and Rechargeable Battery
    Mouse Pad LOLOLOLOLOLOL....
    Headset/Speakers VIZIO SOUND BAR, SUBWOOFER AND SURROUND SPEAKERS
    OS WIN 10 PRO
    AQUASTEVAE's Avatar
    Nov 2011
    11
    377
    Glad to hear this, as I have the CrossHair VI Extreme as well, currently running a R1700. But I have a 3900X on the way. So happy to hear it's running so well on this board. What memory are you using. I have 32GB of the GSkill FlareX 3200C14.
    CoolerMaster Maker 5T - ASUS CROSSHAIR VI EXTREME - 55-inch UHD 4k Display - AMD Ryzen 7 1700 - NZXT Kraken X62 - 7 CoolerMaster/NZXT RGB Case Fans W/ HUE+ - Gigabyte AORUS 1080 TI EXTREME - 32GB GSkill FlareX 3200Mhz DDR4 - Samsung 960 EVO M.2 NVMe 500GB - Samsung 951 M.2 AHCI 512GB - Samsung EVO 840 1TB SSD - Crucial MX100 SATA 3 500GB SSD - WD BLUE 8TB HDD - Logitech K350 wireless wave keyboard - Logitech M570 wireless trackball - Dual booting WIN 10 Pro Fall Creators Edition
  8. #8
    Aug 2018
    32
    Quote Originally Posted by AQUASTEVAE View Post
    Hi this is the one I have in my CH6E Samsung Bdie Corsair CMW16GX4M2C3200C14 I have 4x8GB kit 3200mhz currently oc very stable at 3800mhz with the ryzen dram calculator. I can get stable to 3900mhz but have to keep my flck at 1900 the only downside is I get about 74 latency with 3800mhz my latency are better much better around 59-61
  9. #9
    AQUASTEVAE PC Specs
    OS WIN 10 PRO
    AQUASTEVAE's Avatar
    Nov 2011
    11
    377
    Very nice. I've already installed my 3900X, and put a Kraken X72 in there as well to keep it cool. I'm currently OC to 4474mhz at 1.36125v. Everything is running smoothly, but screwed up my system for two days using the DRAM calculator's "FAST 3600" profile. I need to try the safe profile. Is that the one you are using or not?
  10. #10
    New ROGer Array RedSector73 PC Specs
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)PVR416G413C9K @3800 15-15-15-30 CR1 or @3600 14-15-14-28 CR1
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 10 64bit Pro
    Network RouterRT-AC87U
    Apr 2018
    40
    483
    Can you share your settings in the BIOS.
