QUESTION | GX701 Volume slider skipping by 4%, more are experiencing it?
liplenny26
Hey,
Has anyone even come across this bug?
It's a small problem, but it bothers me a bit
there is no option to control the volume through the keyboard, and there's the volume slider in the gx701
But I notice that each round increases the volume by 4% and not 2%
its a bug? will it be fixed soon?
I'm usually used at nights to use volume at 2%, and the slider in gx701 straight up to 4%
liplenny26
Anyone with GX701 can do this test please?
its important to me, to know if its a bug or some problem
just to scroll the volume whell and to check if the volume is increased by 2% or 4% steps each time.
Thank you!
Retired
Not applicable
yes mine GX701 volumewheel is also skipping by 4%. very annoying
1212321
same here. pretty sure its intended
