Strix Hero III G731GV Bottom/Side LED Off - Resolved
APACHEJP
The LED on the sides and bottom of my laptop is working a while ago, but when I installed the Aura Sync app, it just turned off. I uninstalled Aura Sync and reinstalled the default Armoury Crate but it still doesn't turn the side and bottom LEDs on. Anyone can help out?
APACHEJP
This is resolved. Here are the details for people who may have similar problem.
Problem: LED on bottom and side of laptop is turned off, but keyboard LED is working and can change colors.
Cause: I reinstalled Windows 10 and installed Aura Sync 1.07.66 since I assumed that's the original application used to change LED colors across all Asus products. Upon opening the program, LED on the bottom/sides switched off and no option on Aura Sync was found to turn it on. Aura Sync does allow me to change colors, brightness of the keyboard LED.
Resolution:
- Using CCleaner, uninstall Aura Sync and all the RGB components that installed with it.
- Clean registry and restart
- From the ASUS support website of my laptop G731GV, download and install "ASUS System Control Interface V2", "ROGLiveServicePackage 1.0.9.6", "ARMOURY CRATE Service" (any version)
- Still from the ASUS support website, download and install "ArmouryCrateService & ROGLiveService UpdatePackage" to update.
- From Microsoft Store of Windows 10, download and install "Armoury Crate"
- Restart
- Start Armoury Crate -> System -> Lighting -> Settings -> Lightbar to turn bottom/side LEDs on and sync with the colors you have set for the keyboard.
* you can use Amoury Crate to change the colors of LED, fan speed, view hardware monitoring numbers, etc.
