ROG Strix Flare Restarting Every .5 Seconds (FW Issue?)
eightsixlife
Hello All,
I recently purchased a used Strix Flare and it won't connect to my pc. It keeps restarting or power cycling every about .5 seconds and never has a chance to connect so I can update or check FW. I found this thread and it also looks like this user had the exact same problem.
https://rog.asus.com/forum/showthread.php?106126-Fix-asus-rog-strix-flare-please
Do you guys know if there is a solution available? I read through the sticky at the top of this section but I felt it didn't accurately describe my problem. Any help would be great, thanks in advance!
ChanLum
The sticky post already explain. you have the same problem as me. the problem caused by press the brightness button when booting (not enter the windows yet). The keyboard keep restarting cannot be use anymore. the post tell us to keep happy with it and RMA in the ASUS store, which is not our fault.:mad:
