Audio Problem g752vsk
ourze
hi, i have a problem:
my g752vsk have audio issue when is powered by power supply (with headphones no problem).
when is powered by battery no problem.
what do you think?
9 REPLIES 9
jdfrench3
Level 12
First properly identify your laptop using dxdiag.exe and confirm your System Model and BIOS number.
I used this Realtek audio driver in my G752VSK to great success:
Version 6.0.1.8443 2018/08/24 178.02 MBytes found on the ASUS G703GS support page:
https://www.asus.com/supportonly/G703GS/HelpDesk_Download/
You will need to delete your existing audio driver manually (Program Files x86/Realtek) Simply delete the whole folder with contents. Then install the new driver. The process will require a couple reboots but the installation is complete.
After installation, check Control Panel/ Programs and Features/Realtek High Definition Audio Driver, confirm installation of version 6.0.1.8443.
G752VSK, G75VW-3D, G51J, G1S
Homebuilt Windows Server
try do change driver, but problem persist....
it's possible power supply issue?
First, did you run dxdiag.exe and confirm that you have the G752VSK model and BIOS? What do you have?
Second, did you manually remove your old audio driver first before installing new driver?
What does your battery icon (in lower right) state?
yes.
i check notebook version and is g752vsk with 305 bios.
i manually remove old driver.
battery is ok, full charged
You have yet to identify your actual audio problem while attached to your charging brick. What is the problem?
the problem is the audio is not clear and make strange sounds...like flickering
Strange flickering sounds through the speakers, only. Headphone audio is clear.
Is there a Realtek HD Audio Manager in the Control Panel?
What Realtek audio driver version are you running?
Control Panel/Device Manager/Sound, video and game controllers/Right click on Realtek High Definition Audio/ Properties/Driver Tab
realtek control panel is present.
every version of drivers do the same problem.
is not driver issue for me.
jdfrench3
Level 12
You mean you have the Realtek HD Audio Manager present within the Control Panel?
So if you are through checking software then it must be a hardware issue.
Motherboard, DC-IN sub board, speakers, battery, and/or charging brick.
Good Luck
