Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    New ROGer Array Khean PC Specs
    Khean PC Specs
    MotherboardROG Strix Z390-E Gaming Motherboard
    ProcessorIntel 9th Gen Core i9-9900K OC 5.0Ghz @1.305 Adaptive
    Memory (part number)Corsair Vengeance Pro RGB 2x16 32gb 3200mhz
    Graphics Card #1ROG Strix GeForce RTX 2080ti OC 11gb GDDR6
    Sound CardSupremeFX Onboard
    MonitorASUS ROG Swift PG279Q Gaming Monitor
    Storage #1Corsair Force Series MP510 M.2 NVMe PCIE Gen3 240gb
    Storage #2Seagate Baracuda 2TB Mechanical Hard Drive
    CPU CoolerCorsair Hydro Series H150i Pro RGB 360mm
    CaseCoolmaster Mastercae H500P Mesh
    Power SupplyCorsair RM 750x Gold Certified
    Keyboard HyperX Alloy Elite RGB MX Cherry RGB Red
    Mouse HyperX Pulsefire Surge
    Headset HyperX Cloud Fligth Wireless
    Mouse Pad HyperX FURY S - Pro Gaming Speed Edition Mouse Pad – Large
    Headset/Speakers Samsung HW-M360 Soundbar
    OS Windows 10 Pro 64bit
    Network RouterNetgear NigthHawk M1
    Khean's Avatar
    Jul 2019
    34
    47
    Stable OC 5.0Ghz Guide on i9-9900k
    Hello Guys!
    i need someone who can help me on this matter.
    specs to overclock
    i9-9900k + Z390-E + H150i PRO 360mm AIO
    Thank you in advance.
    New ROGer Array neoforo87 PC Specs
    neoforo87 PC Specs
    Laptop (Model)ASUS ROG STRIX GL753VE-GC133T
    MotherboardASUS ROG MAXIMUS X HERO
    ProcessorI9 9900k
    Memory (part number)Corsair CMT32GX4M4K3600C16
    Graphics Card #1EVGA RTX 2080TI XC ULTRA
    Sound CardASUS XONAR ESSENCE STX II
    MonitorACER XF270HUA
    Storage #1Samsung 860 PRO
    Storage #2WD BLACK CAVIAR 1TB
    CPU CoolerNOCTUA NH-15DS
    CasePHANTEKS ENTHOO PRO
    Power SupplySEASONIC PRIME ULTRA TITANIUM 850W
    Keyboard DAS KEYBOARD PRIME 13
    Mouse LOGITECH G403 WIRED
    Headset MASSDROP 6XX
    Mouse Pad RAZER GOLIATHUS CONTROL EDITION
    OS WINDOWS 7 PRO
    Network RouterNetgear Nighthawk R7000 AC1900
    Aug 2019
    4
    Hi there .
    well I have seen quite a few guides on this subject. My goal was to undervolt/ find the perfect voltage for the cpu (I have an I9 9900k as well).
    Der8auer has a good video on this subject https://www.youtube.com/watch?v=95Ujni7-fVM and the other one is by JJ from Asus https://www.youtube.com/watch?v=jOXH2YIMi2Y.
    Give them a try and see where you land with the clocks.
    My advice on this is, that the I9 9900k is a very hot sucker especially while running AVX loads. I don't know what games u play but for example i found out couple of weeks ago that Battlfield 5 for instance uses AVX.
    So if I were you I'd go for 5GHz with an AVX offset of 3 maybe 2. That means when the cpu will run AVX instructions it will downclock to 4.8 or 4.7 GHz.
    The temps really go out of control when AVX kicks in at 5GHz.
    The difference between 4.7GHz and 5Ghz is really minimal in terms of FPS but huge in terms of Temperature. We are talking of 10FPS max usually more like 5-7FPS.
    Just keep in mind that although you have a good cpu cooler the vrm area will not have the same ventilation as if you would be using an air cooler.
    Go easy on it.
    I hope this helped .
    Khean PC Specs
    Khean's Avatar
    Jul 2019
    34
    47
    Quote Originally Posted by neoforo87 View Post
    Hi there .
    Go easy on it.
    Oh Thank you! ill give a shoot on this one. ill post what will be the output.
    Khean PC Specs
    Khean's Avatar
    Jul 2019
    34
    47
    BIOS OC 5.0 Ghz Settings
    This is what the best OC setup i could do.
ID:	81383Click image for larger version.
ID:	81384Click image for larger version.
ID:	81388Click image for larger version.
ID:	81385Click image for larger version.
ID:	81386Click image for larger version.
    Khean PC Specs
    Khean's Avatar
    Jul 2019
    34
    47
    Benchmarks Aida64, CB_R15, CB_R20, RealBench + Stress Test, 3D Time Spy
    Here my following Benchmarks.
ID:	81389Click image for larger version.
ID:	81390Click image for larger version.
ID:	81391Click image for larger version.
ID:	81392Click image for larger version.
ID:	81393Click image for larger version.
ID:	81394Click image for larger version.
    Khean PC Specs
    Khean's Avatar
    Jul 2019
    34
    47
    MSI Afterburner GPU OC Bonus
    Here is my GPU OC.
ID:	81396Click image for larger version.
  7. #7
    ROG Guru: Diamond Belt Array Zka17's Avatar
    Mar 2012
    199
    8,358
    It is looking good...
    I was curious on your RB testing... I was trying it with the same CPU, but with an air cooler (Dark Rock Pro 4) - your single benchmark produced less heat, but the 15 minutes test is very similar... I am satisfied with the air cooler!
  8. #8
    Khean PC Specs
    Khean's Avatar
    Jul 2019
    34
    47
    Quote Originally Posted by Zka17 View Post
    Dark Rock Pro 4 was my first option but they don't have here in Kuwait. So i went to AIO 360mm instead.
  9. #9
    Mar 2012
    199
    8,358
    No, you are right - I was thinking on the AIOs, but I had a noise concern...
  10. #10
    ROG Enthusiast Array
    Mar 2013
    27
    Quote Originally Posted by Khean View Post
    Hi Khean, sorry to bother you but hopefully you can help me as an amateur at overclocking. I just want to understand, I followed your same settings and I'm getting very high temps and BSOD. What's the first settings I should increase or decrease when this happens to reach a stable OC please?
