Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    ROG Enthusiast Array sigtrm's Avatar
    Feb 2012
    47
    [Armoury Crate][G731GW] CPU LOAD not showing
    There is some problem with CPU info/LOAD screen in Armoury Crate in Home tab.
    Actually there is no info there. GPU seems to be working though.
    Anyone with same problem and fix?
Name:	Annotation 2019-08-08 204516.jpg
    New ROGer Array
    Jun 2019
    1
    I have the same issue with my GX701. Don't have a solution though.
    New ROGer Array
    Jul 2019
    3
    How about BIOS update. Is it up to date?
    Feb 2012
    47
    Quote Originally Posted by MmikiM View Post
    yes it is, no change.*
    New ROGer Array
    Jul 2019
    3
    Once you get into the BIOS, does it show any info about the CPU or not? If yes, try to reinstal the Armoury Crate, if no how about Intel drivers?
    New ROGer Array
    Sep 2019
    2
    Unhappy The same
    Hello, I have the same problem in a G531GU, it does not show the cpu info,
    I do not know how to solve this problem.
  7. #7
    New ROGer Array
    Jun 2019
    3
    It is the problem with the Armoury crate software. If a restart doesn't fix the problem, terminate the program in Windows setting and do a reset on the Armoury crate app. It will reinstall it via Microsoft store with the latest available Armoury crate. (P.S: Remember to login and backup in the application should you have settings made, and you can restore it once it's being reset.)
  8. #8
    New ROGer Array
    Aug 2019
    5
    Mine also stop working today. And so does intel extreeme tuning utility. The issue might be a windows update that kills the processor tuning library. That's my suspicion
  9. #9
    New ROGer Array
    Sep 2019
    1
    The same thing happened for me. Installed extreme tuning utility..and uninstalled soon without making any changes. Soon after uninstalled, its stopped to show cpu usage. Any solution for this?
  10. #10
    New ROGer Array
    Aug 2019
    1
    CPU hiden status
    Same problem here.... don t know how to resolve...
