Results 1 to 10 of 10
    ROG Enthusiast Array
    Sep 2014
    26
    Crazy issues with my R6E Omega
    I get blue screens trying to install windows (1809) unless i disable my wireless onboard adapater in the bios. I assume its a driver bug.
    I can not for the life of my get bluetooth to work. When trying to troubleshoot it says this device (my PC) does not have bluetooth.
    Bluetooth is enabled in the bios.
    I have tried multiple different versions of the bios (on latest currently)
    ROG Guru: Orange Belt Array
    Feb 2019
    67
    260
    Stupid question but did you download and install the latest version of the driver? Windows drivers dont always work and are often not as good as what the mobo manufacturer and one further the actual chip manufacturer. BT and having other USB devices plugged in or even enabled in are top contenders for the title of most problems during installs.
    Have you tried downloading 1903 media tool and moving to latest release?
    My brain may not be on the correct timeline but I think the board came after 1809.
    If all else fails dont waste too much time as the warranty clock is ticking.....
    My bet is it can be easily fixed with software and/or drivers.
    ROG Guru: Orange Belt Array vmanuelgm's Avatar
    Sep 2013
    32
    315
    Quote Originally Posted by lukeyboy89 View Post
    Just install the latest drivers for Lan WiFi and Bluetooth (the most problematic are Aquantia and Intel WiFi) components during the Win10 1809 (or latest) installation. U have the option in Win10 setup (load drivers). Latest drivers:
    https://www.station-drivers.com/inde...id=169&lang=fr
    Omega, 7980xe, G.Skill 3600, 2080Ti, SM951 256, 970 PRO, 860 EVO
    Intel 750, WD SN750 Black, 840 Pro, 2xSkyhawk 4TB, 7200.14, 207EBK
    EVGA T2 1600, Silverstone TJ11, Custom LC. @Acer Predator x34
    Sep 2014
    26
    I have installed the newest drivers.
    The bluetooth device does not even show up in device manager.
    Wifi seems to work fine though.
    Sep 2013
    32
    315
    U should open RMA to check that BT WiFi module, maybe defective...
    ROG Guru: Brown Belt Array LiveOrDie PC Specs
    LiveOrDie PC Specs
    MotherboardASUS RAMPAGE VI EXTREME OMEGA
    ProcessorIntel Core i9 7980XE Custom IHS @ 4.6Ghz 1.23v
    Memory (part number)G.Skill Trident Z RGB F4-3000C14D 64GB
    Graphics Card #1AORUS GeForce RTX™ 2080 Ti XTREME WATERFORCE WB 11G
    MonitorLG 4k 43inch
    Storage #1Samsung 960 Pro NVME 512gb
    Storage #2Samsung 850 Evo 1TB x 2
    CPU CoolerEK-Velocity , EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
    CaseCorsair Obsidian 500D SE ATX-E Modded
    Power SupplyCooler Master Vanguard Series 1000W
    Keyboard Logitech G910
    Mouse Logitech G900
    Headset Razer Tiamat 2.2 v2
    OS Windows 10 x64
    Network RouterNetGear
    LiveOrDie's Avatar
    Dec 2011
    41
    1,680
    This issue is pretty common even on other boards using the same Wifi, you need to disable it then install the drivers then turn it back on, or like me just turned it off and left it off.
  7. #7
    Sep 2014
    26
    Quote Originally Posted by LiveOrDie View Post
    What do you mean disable it? I can't even find a way to enable it.
  8. #8
    ROG Guru: Orange Belt Array Super Gnome PC Specs
    MotherboardROG Rampage VI Extreme Omega / ROG Crosshair VIII Formula
    ProcessorIntel® Core™ i9-9980XE / AMD 3950x
    Memory (part number)Corsair LPX Vengeance DDR4 2666MHz 128 GB / Corsair Vengeance LPX 32GB DDR4-3200 32GB DDR4 3200MH
    Graphics Card #1Asus 2080 Turbo / Asus 2080 ti Turbo
    Graphics Card #2Asus 2080 Turbo / Asus 2080 ti Turbo
    MonitorJAPANNEXT JN-VT500UHD 4K 50-inch LCD
    Storage #1Crucial MX500 1 TB / Sabient SB-ROCKET-NVMe4-500
    Storage #2Samsung 970 Pro 1 TB / ADATA XPG SX5500 Pro 3D NAND NVMe Gen3x4 PCIe M.2
    CPU CoolerROG Ryujin 360 / NZXT Kraken X62
    CaseThermaltake View 71 TG / Thermaltake View 31
    Power SupplyCORSAIR AXi Series, AX1600i 1600 watt / Thermaltake Toughpower iRGB 1200 watt
    Accessory #1 Noctua 140mm 3000 RPM x 4 / Noctua 140 mm 3000 RPM x 2
    Accessory #2 Gigabyte GC-A 2WAY NVLINK RGB (3-slot) / ROG NVLINK Bridge 3-Slot A
    Mar 2019
    11
    295
    The Bluetooth hardware, if I recall correctly is courtesy of Intel, is it not? Hence, I'd install and run Intel's driver support assistant. I run it every day at startup and it actually works trouble free, in contrast to you know what. Anyhow, here is a link: https://downloadcenter.intel.com/dow...port-Assistant
    Hopefully that helps. It helped me when I had problems with my R6EO. Good luck!
  9. #9
    Sep 2014
    26
    Quote Originally Posted by Super Gnome View Post
    https://i.imgur.com/RGeM6v3.png
  10. #10
    Mar 2019
    11
    295
    All well and good. Thanks for the photo. I'd post a photo for you myself, but I have the same motherboard, and checked for you (I'd posted the above reply while on another computer). The hardware is indeed Intel Bluetooth Wireless. If you can download that Intel app (from the link above or Google Intel Driver & Support Assistant)--just double check to make sure it is the right one for your windows version, etc--then it will very likely fix you up, trust me. Been there, done that. Good luck. If you want to update this afterwards and still need help I will try to help you further based on my own experience (and countless Google searches, etc) with the board.
