Results 1 to 2 of 2
    ROG Enthusiast Array SirRobin PC Specs
    SirRobin PC Specs
    MotherboardASUS ROG Crosshair VI Hero
    ProcessorAMD Ryzen 5 1600x
    Memory (part number)G.Skill RipJaws V KIT 16 GB DDR4-3000
    Graphics Card #1ASUS ROG Strix GeForce GTX1060-O6G
    Sound CardOnboard
    MonitorDell S2417DG
    Storage #1Samsung NVMe SSD 960 250 GB
    Storage #2Western Digital Green HDD 3 TB
    CPU CoolerNoctua NH-U12S SE-AM4G
    Casebe quiet! Dark Base 700
    Power SupplySeasonic Focus Plus 550W
    Keyboard Logitech G213
    Mouse Logitech G403
    OS Microsoft Windows 10 64 Bit
    SirRobin's Avatar
    Dec 2017
    25
    Question Best CPU Fan smoothing up/down time setting?
    Hi@all,
    i´m currently looking for some optimizations for my system, a Ryzen 5 1600x based Gaming PC. Fan Setting for CPU and Chassis in in PWD mode.
    Not even in peaks (starting steam, an other program or even games), the fan speeds up and mostly down a little later.
    What do you thing is the best FAN smooth up/down setting without running in problems? Fans should spin up if needed but as silent as possible...
    Thank you
    New ROGer Array
    Jul 2019
    9
    Post
    You can set your fan curve to run on minimun speed and to run higher speed when your cpu reach 50 or 60 degrees.
    Personally, I use a fan smoothing with 15 seconds and my fan curve starts at 60 degrees C because I like it silent on desktop workload.
Tags for this Thread
