Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    New ROGer Array fapb48 PC Specs
    fapb48 PC Specs
    MotherboardROG CROSSHAIR VII HERO (WI-FI)
    ProcessorAMD Ryzen 3700X
    Memory (part number)CMK16GX4M2D3000C16
    Graphics Card #1AMD Radeon RX Vega 56
    MonitorSamsung UE590 Series
    Storage #1Samsung SSD 860 EVO 1TB
    Storage #2Samsung SSD 970 EVO Plus 500GB
    CPU CoolerThermaltake Floe Riing 360
    CaseThermaltake View 32 TG RGB
    Power SupplyEVGA 750+G
    Keyboard Razer Cynosa
    Mouse Logitech MX Master
    Headset Hyper X Cloud Flight
    OS Windows 10 Pro
    Jul 2019
    8
    ROG Crossair VII Hero Wifi witn Ryzen 3700x CPU 0 RPM
    I have built a pc recently with Crossair VII hero + Ryzen 3700x and thermaltake riing 360.
    From time to time my pc shuts down or reboots itself.
    Last time it shutdown i powered back on, and on POST said CPU overheating or something like that.
    And every time i go onto the AI Suite says CPU Fan 0RPM, but then i have AIO Pump at 1800rpm.
    I am trying to troubleshoot why the PC is shutting down at least once a day (i leave it on 24/7) but i cant seem to find out.
    Is this a potential cause? MOBO is running the latest BIOS
    Thanks in advance.
    New ROGer Array
    Aug 2019
    11
    could be several things to be honest....make sure your have all fan and pump headers are plugged in properly...i wonder if your aio pump is a dud if your system is suddenly powering off due to over heating....
    fapb48 PC Specs
    OS Windows 10 Pro
    Jul 2019
    8
    Quote Originally Posted by TXTerror View Post
    Thanks for your reply. What does dud means? lol
    It gone trough a few days when everything seemed fine but now its back again. There was this day when suddenly the pc became very very slow for 5 minutes and then just shutdown.
    Do you think i should remove the AIO block and try to install again?
    Thanks
    New ROGer Array
    Aug 2019
    fapb48, does it happen on the latest beta bios 0002 for you? Fan stopping is well known issue with older bioses when you use some soft which pokes at Asus WMI, like HWINFO for example. Try different monitoring software for a test (Coretemp works for me) and see if it helps, but in general fan issues should be fixed in the next official bios.
    fapb48 PC Specs
    OS Windows 10 Pro
    Jul 2019
    8
    Quote Originally Posted by UncleHunk View Post
    Thanks for your reply,
    Yes i looked yesterday to see if it had any update and i updated to the latest version. Woke up this morning the pc was turned off again. It's so strange.. On the AI Suit 3 the CPU Fan is always 0rpm.. it doesnt seem normal at all...
    ROG Guru: Blue Belt Array gupsterg PC Specs
    gupsterg PC Specs
    MotherboardAsus Maximus VII Ranger
    Processori5 4690K
    Memory (part number)HyperX Savage 2400MHz 16GB
    Graphics Card #1Sapphire R9 Fury X (1145/545 Custom ROM)
    MonitorAsus MG279Q
    Storage #1Samsung 840 Evo 250GB
    Storage #2HGST 2TB
    CPU CoolerThermalRight Archon SB-E X2
    CaseSilverstone Temjin 06
    Power SupplyCooler Master V850
    Headset/Speakers HyperX Cloud
    OS Win 7 Pro x64 / Win 10 Pro x64
    gupsterg's Avatar
    Feb 2015
    102
    985
    Quote Originally Posted by fapb48 View Post
    Thanks in advance.
    Reads like the Super IO Chip is crapping out.
    The Super IO Chip (IT8655E) has issues with the way and number of apps that access it. ASUS to mitigate the issue brought out ASUS WMI. This is a two fold fix, software accessing SIO must use it and UEFI must have working implementation.
    So first off remove any software that could be accessing SIO, things like Ai Suite, Aura, etc. Don't have other company SW which does similar, ie iCue, etc.
    Next update to beta UEFI 0002, this has working ASUS WMI.
    Use apps which use ASUS WMI, I know latest AIDA64/CPU-Z/HWINFO do.
    Intel Defector AMD Rebel
    TR 1950X - Custom WC - Asus Zenith Extreme Alpha - G.Skill Trident Z 3400MHz C14 QC - RX VEGA 64
    R5 3600 - Custom WC - Asus Crosshair VII Hero Wifi - G.Skill Ripjaws V 3800MHz C16 - Sapphire HD 5850 Toxic
    24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
    Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
  7. #7
    fapb48 PC Specs
    OS Windows 10 Pro
    Jul 2019
    8
    Quote Originally Posted by gupsterg View Post
    Thanks. I have uninstalled Ai Suite and Aura. Now, dummy question. Where can i update the UEFI? cannot find on the motherboard support page.
    Thanks again
  8. #8
    gupsterg PC Specs
    Processori5 4690K
    MonitorAsus MG279Q
    Storage #2HGST 2TB
    gupsterg's Avatar
    Feb 2015
    102
    985
    Unfortunately not on ASUS offical support page, Shamino aka Peter Tan shared it in this post, if link doesn't work I can share one.
  9. #9
    fapb48 PC Specs
    OS Windows 10 Pro
    Jul 2019
    8
    So, i have installed version 0002 and on boot i had to disable the fan speed option because it said CPU Fan speed error detected. This happened to me before on my very 1st boot.
    If the system shuts down i will let you know.
    Thank you very much
  10. #10
    ROG Member Array Daisy81 PC Specs
    Daisy81 PC Specs
    MotherboardASUS Crosshair VII Hero
    ProcessorRyzen 7 2700X
    Memory (part number)CMR32GX4M4C3200C16
    Graphics Card #1MSI GeForce GTX 1080TI Gaming X
    MonitorSamsung LU28E590DS/ZA
    CPU CoolerThermaltake M360 Plus Water Cooling Kit
    CaseThermaltake View 91 TG RGB
    Power SupplyCorsair AX1600i
    Keyboard Logitech G613
    Mouse Razer Naga Epic Chroma
    OS Windows 10 Pro
    Aug 2018
    18
    I’m not sure if the board ever resolved the issue of running monitoring software looking at a sensor on the board causing the board to shutdown without warning. To see if this is your issue close your monitoring software and see if it continues to shutdown.
Tags for this Thread
