08-18-201901:59 PM - last edited on 03-06-202407:51 PM by ROGBot
Hi! I just put together my first build and I get no display to my monitor. The qled on my motherboard is stuck on dram with a constant yellow light. I've tried different ram and tried all possible slot combinations but no dice. I've also checked all my connections and everything is in the correct place and secure. Everything else seems to run fine so I'm thinking it's possibly the motherboard or gpu but I honestly wouldn't know.
My specs are: CPU: Intel - Core i7-8700K 3.7 GHz 6-Core Processor CPU Cooler: CoolerMaster Hyper 212 Evo CPU cooler Motherboard: Asus Prime z390-A Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory Storage: Samsung - 860 Evo 500 GB 2.5" Solid State Drive Video Card: MSI GeForce RTX 2070 8 GB Power Supply: EVGA - Corsair - TX-M Series TX550M Monitor: Asus - VG248QE 24.0" 1920x1080 144 Hz Monitor
Not sure if this helps, but that sounds familiar. Is everything new? Do you have any way to check everything, for example your monitor, with other systems/components? Have you double checked your manual for something you may have missed? Are you getting beeps from the motherboard speaker? Are the fans running? Are you sure your ram sticks are seated properly? Are they compatible? I have had problems when stuff was not seated properly... Good luck!
