Results 1 to 7 of 7
    ROG Member Array D Luniz PC Specs
    D Luniz PC Specs
    Motherboardmaximus vi hero
    Aug 2015
    11
    G752VS Battery is draining when under load
    When Im playing Eve Online, I notice my battery has been draining down to 75%, and starts to recover once I alt tab from the game. This is the only time it is doing this, so Im not sure if its an issue with the battery or the power supply
    ROG G752VS OC Edition 7th gen
    ROG Guru: Blue Belt Array
    Nov 2012
    75
    787
    I'm not a heavy gamer so I don't see any battery drain with my G752VSK. My laptop is only two years old. My battery still reports "Fully Charged 100%".
    Are you using any USB connections while gaming?
    G752VSK, G75VW-3D, G51J, G1S
    Homebuilt Windows Server
    ROG Member Array
    Jun 2017
    21
    9
    Quote Originally Posted by D Luniz View Post
    This is fairly standard behavior and has been covered before. I have the 6th gen version and the same thing happens to mine unless I set the profile to standard in gaming center or use throttle stop to under volt and restrict the oc.
    ROG Guru: Orange Belt Array navis995's Avatar
    Oct 2014
    50
    320
    Its normal.
    The adapter cannot give enough power so it use the battery.
    Mind you this happens on all gaming laptops except those where the power is met with the adapter.
    Asus Rog G750JZ
    Screen: 1920x1080 17.3'
    CPU: Intel® Core™ i7-4700HQ (3.4Ghz @ -70mV)
    GPU: GeForce GTX 880M 4GB (OC +125Mhz Core, +600Mhz Memory @ 1.062V)
    RAM: Samsung 32GB 1600MHz
    Storage #1: Samsung Evo 840 250GB
    Storage #2: Samsung Evo 850 500GB
    Storage #3: Seagate Barracuda 2TB
    Storage #4: Samsung Evo 128GB MicroSD
    ROG Guru: Brown Belt Array Darnassus PC Specs
    Darnassus PC Specs
    Laptop (Model)G752VS -=-=- G750JX
    MotherboardASUSTeK COMPUTER INC. G752VS (U3E1) -=-=- ASUSTeK COMPUTER INC. G750JX (SOCKET 0)
    Processori7 6700HQ @ 2.60GHz -=-=- i7-4700HQ CPU @ 2.40GHz - 3.40GHz
    Memory (part number)2x16gb (M471A2K43BB1-CRC) -=-=- 2x8gb (HMT41GS6AFR8A-PB)
    Graphics Card #1GTX 1070 (8GB) -=-=- GTX 770M (3GB)
    Sound CardRealtek High Definition Audio / NVIDIA High Definition Audio
    MonitorGSync IPS 75HZ -=-=- Chi Mei 60Hz (Overclocked to 85Hz)
    Storage #1Samsung SSD 960 EVO 250GB x2 -=-=- LITEONIT LCS-256M6S
    Storage #2HGST HTS721010A9E630 -=-=- ST1000LM024 HN-M101MBB
    CPU CoolerStock -=-=- Stock
    CaseStock -=-=- Stock
    Power SupplyStock -=-=- Stock
    Keyboard Stock -=-=- Stock
    Mouse Razer Naga Epic 1st Generation
    Headset SPH 2500
    Mouse Pad Razer Goliathus
    OS Winblows 10 Pro -=-=- Winblows 8.1 Pro
    Network RouterCG3000v2
    Darnassus's Avatar
    Dec 2013
    61
    1,653
    I've got the Non OC edition, I don't have this problem.
    What's your overclock settings? You could revert them to stock, then slowly creep up until the drain disappears.
    Personally I think you should revert to stock speeds on the G752VS, keep it under 75*C if possible. :f
    Gosh Blue Lady.. ❤
    JOIN THE ASUS T-SHOOT DISCORD <-- Clicky!
    ROG Guru: Green Belt Array
    Feb 2019
    118
    543
    Normal because the brick cant supply enough power. All the higher end models do it. I know my G752VY does.
  7. #7
    Darnassus PC Specs
    Headset SPH 2500
    Darnassus's Avatar
    Dec 2013
    61
    1,653
    Perhaps undervolt then. You should never drop below 95% on charge.
    Gosh Blue Lady.. ❤
