Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
Thread: Sound Card Pick
    ROG Enthusiast Array martine-dee PC Specs
    MotherboardASUS ROG Strix X299-E Gaming
    ProcessorIntel Core i7-7820X 3.6 GHz @ 4 GHz
    Memory (part number)CMK32GX4M4A3200C16
    Graphics Card #1ASUS GeForce GTX 1080 Ti Strix Gaming, 11 GB VRAM
    Sound CardCreative Sound Blaster AE-9
    Monitor2x ASUS VG248QE, 24"
    Storage #12x SSD: WD Blue 1 TB, WD Black 1 TB
    Storage #2HDD: WD Red, 1 TB
    CPU Coolerbe quiet! Dark Rock Pro 3
    Casebe quiet! SILENT BASE 800
    Power Supplybe quiet! Dark Power Pro 11 1000W
    Keyboard SteelSeries Apex 7, Red
    Mouse Logitech G403 @ 3200 dpi
    Headset DT 770 Pro
    Mouse Pad Logitech G240
    Headset/Speakers Creative Inspire T6300
    OS Ubuntu 16.04, Win 10 Home 64bit, 1903
    martine-dee's Avatar
    Sep 2017
    52
    44
    Sound Card Pick
    I am on the lookout to get a sound card. So far I have been using the MOBO (ASUS ROG Strix X299-E Gaming) and the Graphics Card (ASUS GeForce GTX 1080 Ti Strix Gaming, 11 GB VRAM) built-in ones. Full config is in the profile. And here is my situation:
    It is very comfortable for me to plug my DT 770 Pro headphones into a VG248qe that receives sound via DisplayPort, which is why I use Graphics Card's sound.
    Now, as I see consideration points, they would be:
    - Is it possible to reroute the sound card's output via the graphics card into the DP? If not, I prefer to get sound through a 2 m extension wire (analog, 3.5 mm). Anything I should be aware of in that latter option? Any recommendations?
    - Is there a sound card that works well both under Windows 10 1903 and Ubuntu 16.04? If not, let's focus on Windows and gaming.
    - Let's focus on what integrates best with the MOBO and has great driver support.
    Let the race begin. Thanks!
    A Quaker here
    Headset DT 770 Pro
    Sep 2017
    52
    44
    Oh, P.S. There is some screeching in the sound from the MOBO sound card when playing. It seems to have the frequency of fps generation. That is another reason I don't use the MOBO sound card for gaming.
    A Quaker here
    Headset DT 770 Pro
    Sep 2017
    52
    44
    Okay, are there particular brands that I can focus on? Back in the late 1990s I was sticking to Creative, but I've heard quite a few people unhappy with them from vague reasons. I'm open to consider new brands.
    A Quaker here
    ROG Guru: Black Belt Array toronto699 PC Specs
    toronto699 PC Specs
    Laptop (Model)G752-VY-DH78K , G751-JYDH72X
    MotherboardRog Tytan G30AB
    Processori7-4770K
    Memory (part number)32GB
    Graphics Card #1Asus Gold20th GTX980Ti
    Sound CardDell X-Fi Audigy SoundBlaster
    Monitor3 Acer K272HL
    Storage #1118 GB/OS
    Storage #22.72 TB
    CPU CoolerIntegrated Liquid-Cooled CPU
    CaseG30AB
    Power SupplyAsus 700 Watt
    Keyboard Razer BlackWidow Ultimate
    Mouse Razer Diamond Back
    Headset Sony Studio Professional , Razer Seiren Mic
    Mouse Pad Razer FireFly
    Headset/Speakers Logittech 5.1 Z-5500
    OS W 10
    Network RouterSagemon Fast 5250 Hub 2000
    Aug 2014
    74
    2,424
    Creative Is Way To Go, Sound Blaster Is Way To Go , I Have 5.1 and 7.1 Audio Systems , No Issues , Sound Blaster Audigy Rx and Sound Blaster Audigy FX Or External Sound Card if You Like , Do You Use Headphones Or Speakers ? Games , Music , Movies? How Much You Want to Spend ?
    The Drivers Are Basically The Same For Every Sound Blaster Sound Card , Just Different Hardware Features , Why Audio Is All Messed Is A W 10 Issue In Most Cases , Dedicated Audio Drivers Fixes That Issue When New Drivers Are Released For Sound Card Makers , Sound Blaster Is Good At Fixing W10 Issue And Driver Issues , I Had 2 Asus Sound Cards , Returned Them , Issues Driver Issues , Over Year For FIX By ASUS
    I HAVE MESSAGE FOR ASUS < YOU WANT TO SELL ME SOMETHING < THEN SUPPORT IT OR GET OUT OF PC BUSINESS GAMING BUSINESS
    https://www.soundblaster.com/
    https://www.soundblaster.com/products/soundcards
    https://forums.guru3d.com/forums/sou...le-formats.23/
    ROG Guru: White Belt Array
    Dec 2011
    97
    EVGA has recently released a soundcard as well. Seems to have good reviews. I've been using Soundblasters since '95. They aren't that great with driver updates though. For example, they're still actively selling the ZX series but the drivers were updated last in 2017 and don't play well with the latest 1903 Win 10 update. Their newest models are the AE-9 & AE-7. I still like my ZX-R though. Now that they've identified the cause of the DTS / Dolby Digital Encoding issues with Win 1903 I have no reason to upgrade to anything else. I'M also not a fan of all of this RGB nonsense on the newer cards either.
    May 2014
    28
    102
    ASUS Essence STX II dominates them all especially when you have that motherboard ,running same board with it and just plain good ole ASUS drivers from there website.
    Asus Rampage VI Extreme / Intel I9-7940X / Corsair H115i Pro / CORSAIR Vengeance RGB Pro 32GB (4 x 8GB) 3000MHz / EVGA GeForce GTX 1080 Ti FTW3 ELITE GAMING BLACK Edition / 2x Samsung 970 Pro NMVe 1GB / 4x Samsung 850 PRO - 2TB / Asus ROG Swift PG348Q / Corsair AX 1500i / Thermaltake View 71 RGB PC Case /Win 10 PRO x64
  7. #7
    Headset DT 770 Pro
    Sep 2017
    52
    44
    Yes, Windows 10, 1903 user here. It seems like I am up for a hard time. Let's say I get a Sound Blaster AE-9. Still, conversations on waiting for new drivers seem to be going on for years. The drivers are still 1-2 years younger than the STX II drivers tho.
    Quote Originally Posted by EaglePC View Post
    ASUS Essence STX II
    Thanks for the new angle. I've read a few articles about it, it sounds like a great card when it comes to quality, though it may not be the right pick for me.
    It is quality sound all right. Here I see that the card is big on keeping down the noise and distortions. It may seem an overdo for just plugging 3.5 mm headphones in, so that's the question of return for the value invested.
    Molex may be a bit upsetting, non-trivial setup as well but let's keep those in a corner.
    What about EMI shielding? With my Realtek HD Audio, I'm getting screeching at the ~frequency of frame rendering. It is so strong coming from the other monitor that I can hear it through headphones in NVIDIA HD Audio. Particularly while STX II seems to have some of its body covered, the SBZ has most of itself shielded. Is that the same quality/type of shielding? I would place high value on it.
    A Quaker here
  8. #8
    Headset DT 770 Pro
    Sep 2017
    52
    44
    In fact, now that I dug it up, I am considering AE-9.
    It should become available soon.
    A Quaker here
  9. #9
    Headset DT 770 Pro
    Sep 2017
    52
    44
    Here, reveal of the AE-9.
    https://www.youtube.com/watch?v=7ixWEb93aeI&t=52m42s
    I want it.
    A Quaker here
  10. #10
    toronto699 PC Specs
    Processori7-4770K
    Storage #1118 GB/OS
    Storage #22.72 TB
    CaseG30AB
    OS W 10
    Aug 2014
    74
    2,424
    AE-9 Nice Card ,
