New build no power on
unclepauly28
I did a new build with A Maximus XI Extreme, i9-9900k, 64GB RAM and a Corsair AX1600i PSU. When I turn on PSU the motherboard's RGB lighting comes on, the status window does not light and the computer will not power on. All connections have been checked and double checked and ask are tight and secure. Any suggestions?
Here it is. Finally finished.
CASE HAF X;
PSU CMPSU- 1200AX
MB ASUS Maximus V EXTREME
CPU i7-3770K
COOLER Corsair H100
RAM G.SKILL Ripjaws 32GB (4 x 8GB)
mSATA DRIVE M4 CT256M4SSD3 256GB
SSD SAMSUNG MZ-7PC512N/AM 512GB x2 RAID 0
HDD WD 2TB x2 RAID 1
OD 1&2 Pioneer BDR-207DBKS X 2
OD 3 ASUS DRW-24B1ST
VIDEO ASUS MARS 2 GeForce GTX 580 3GB
SOUND SB X-Fi Titanium HD
MOUSE Cyborg R.A.T. 7 Albino Edition
MrAgapiGC
try with 1 stick of memory and if you can reseat the cpu
Learn, Play Enjoy!
davemon50
Level 11
The PSU is on but how are you starting it up? Are you using the case start button? If so, pull your Q-connector and check you have them all plugged into the correct locations, and reseat.
Davemon50
