Results 1 to 10 of 46
08-19-2019 04:24 PM #1
weare PC Specs Motherboard Asus ROG CROSSHAIR VI HERO (WI-FI AC) Processor AMD Ryzen 7 3700X Memory (part number) F4-3200C14D-32GTZR Graphics Card #1 Asus ROG Strix RX VEGA56 Monitor Multiple CPU Cooler Noctua D15S Case Fractal Design Meshify C Power Supply Be Quiet! STRAIGHT POWER 11 OS Arch Linux
- Join Date
- Aug 2019
- Reputation
- 10
- Posts
- 9
Crosshair VI Wifi, fan control / sensors are broken
Hello.
I'm using c6h wifi motherboard with 3700x CPU and currently experiencing a lot of problems with fan control / sensors on recent bios versions. I did expect some problems when i was building this system (bleeding edge bios, etc), but i never thought there will be so much issues with such a basic functionality as temperature control.
I have 1 CPU fan and 3 PWM case fans (Noctua A14/A12). #1 and #2 case fans should change RPM depending on CPU temperature, and #3 depends on PCH temperature. Basically it works fine for some time (usually 2-10 hours), but then the expected behavior breaks in many different ways:
1. This is the most common issue i'm experiencing right now. Usually fans should spin around 800-900 RPM when the system is in idle state. When this problem happens, RPM decreases to 400-500 and the more i load my CPU the less RPM i get until fans completely stop. And it happens to all CPU-related fans. This is so ridiculous i even made the video — https://streamable.com/i3379 where you can see the idle behavior (~400 rpm) and what happens when i load my CPU using 'stress' utility. I've tried different fan profiles (silent, standard, etc), different low speed, delays and nothing changed. I've checked and can confirm that fans are really stopping, so it's not just monitor tool issue. The fix is to reboot the system.
2. Motherboard temperature sensors just stop working and hang up on the last value it was, even though RPM sensors still work. Once more, it's not the monitoring tool related problem because fans aren't changing the speed if i load my CPU. For instance, if CPU temperature hangs up on ~50C temperature, fans will still have ~800 RPM even if i stress my CPU (usually in this case RPM should increase up to 1500). The fix is to reboot the system.
3. Fan is just completely ignoring the component's temperature. I had this issue on my fan #3, which wasn't changing idle RPM even though my PCH temperature was already around 80. The fix is to reboot the system.
4. Fan gets stuck at 100% RPM. This usually happens on my fan #3 when i cold boot my system. Rebooting the system didn't help me though, i had to clear CMOS (or make some changings in the bios) to fix this.
So basically my system is barely usable right now, i have to constantly monitor the sensors and regularly reboot my system when something breaks again. Otherwise this behavior can possible damage my CPU/motherboard due to overheat in high-load scenarios. As far as i can see, other people are experiencing pretty much similar fan-related problems i do, so it's not just defect motherboard i have.
I've been using ASUS motherboards for 17 years starting from P4PE and you can imagine how disappointed i am right now. In my opinion this kind of issues are critical and should be investigate ASAP. I hope my report can be useful, and this situation won't end with changing motherboard to another vendor.Last edited by weare; 08-19-2019 at 11:53 PM.
08-20-2019 02:53 PM #2
- Join Date
- Aug 2019
- Reputation
- 10
- Posts
- 9
Trying to find the less broken bios and still no success.
Issue #1 appears on 7306 and probably 7201
Issue #2 happened just a few times and i'm not quite sure if i experienced it anywhere besides 7201 (but probably other versions are affected as well)
Issue #3 appears on every bios including 7306, 7201 and 7106
Issue #4 isn't that critical since it can be fixed by clearing CMOS, but it happened on multiple bios versions as well
08-22-2019 11:04 AM #3
IIINikolaiIII PC Specs Motherboard Asus ROG Crosshair VII Hero Processor Ryzen 5 3600 Memory (part number) 16GB Crucial Ballistix 3600 CL16 Graphics Card #1 Asus TUF RTX 3070 Monitor Acer Predator 27" XB273UGS CPU Cooler Noctua NH-D15s Case Fractal Design Define R5 Power Supply Superflower 850W Leadex Gold Keyboard ROG Strix Flare Mouse Glorious Model D Headset Sennheiser HD599 OS Windows 10 Pro 20H2
- Join Date
- Jun 2018
- Reputation
- 10
- Posts
- 35
I have same issues with C7H where all of my fans just stop and causes a thermal shutdown. Still looking for a solution.
08-22-2019 12:34 PM #4
- Join Date
- Jul 2011
- Reputation
- 103
- Posts
- 790
hi can you try this version to see if issue disappears?
https://www.dropbox.com/s/6ts6dclcqw...-0002.rar?dl=0
let me know whether yes or no
Edit: (check potential fix)
c6h wifi
c6h non wifi
https://www.dropbox.com/s/fcna089f3y...-0002.rar?dl=0
c6e
https://www.dropbox.com/s/8t34vcfn09...-0003.rar?dl=0
c7h wifi
https://www.dropbox.com/s/f71clkig2i...-0002.rar?dl=0
c7h non wifi
https://www.dropbox.com/s/5rzk9nt5v2...-0002.rar?dl=0
Strix B450 -E
https://www.dropbox.com/s/8btojisa3b...-0002.rar?dl=0
Strix X470-I
https://www.dropbox.com/s/1bw0wm22bf...-0002.rar?dl=0Last edited by Shamino; 08-23-2019 at 06:05 AM.
08-22-2019 01:56 PM #5
- Join Date
- Jun 2014
- Reputation
- 10
- Posts
- 2
hi*Shamino, can you post test bios also for my mobo?*regular crosshair vi hero (non wifi)
I have the same problem with the fans that suddenly stop working, also at the boot the fan of my Nvidia rtx 2080 start at 100% then return to normal after 4-5 seconds,*on overclock.net forum many users have same bug
thank you*
08-22-2019 02:51 PM #6
- Join Date
- Aug 2019
- Reputation
- 10
- Posts
- 9
08-22-2019 04:31 PM #7
- Join Date
- Jul 2011
- Reputation
- 103
- Posts
- 790
08-22-2019 04:32 PM #8
- Join Date
- Jul 2011
- Reputation
- 103
- Posts
- 790
08-22-2019 10:58 PM #9
jeffersonpl PC Specs Laptop (Model) Macbook pro 2012 Motherboard asus rog crosshair VII hero wi-fi Processor ryzen 5 3900x Memory (part number) Gskill Trident Z Royal Silver 3600mhz 16gb Graphics Card #1 RTX 2070 strix Monitor ASUS ROG Strix xg32vq Storage #1 m2 reeino 512 Storage #2 1 tb barracuda seagate CPU Cooler evga clc 280 Case core p5 thermaltake Power Supply nzxt 700 halo Keyboard Asus ROG Claymore Mouse logitech g502 hero Headset logitech g633 Mouse Pad razer goliaths Headset/Speakers logitech g633 OS windows 10
- Join Date
- May 2018
- Reputation
- 10
- Posts
- 5
Hello I took the freedom to test too, because I was having the same problem, apparently improved a little, but there is still a lot of temperature fluctuation, I noticed that is giving a drop in the speed of the fans, even though I put everything in full, I kept it in my The processor over 4.4ghz, with vcore 1.4v, is stable, then I will test memory clock, was not having much success above 3600mhz.
Obs1:
I did some more tests, in memory, with this bios I could use with 3800mhz 1: 1, infinity fabric with 1900mhz, after almost 5 minutes got error in memtest with the pc shutting down, before I could not even pass 3600mhz. I think it's on the way! Congratulations!
08-23-2019 03:17 AM #10
- Join Date
- Jul 2011
- Reputation
- 103
- Posts
- 790
