Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 31 to 40 of 46
  1. #31
    ROG Guru: White Belt Array
    Feb 2018
    14
    77
    Quote Originally Posted by Shamino View Post
    yes f9 is dram related
    just checking if it actually boots with the right dram voltage, set both dram vboot voltage (under digi vrm) and dram voltage to whatever is needed / used.
    When are you going to take the issue with some CPUs not boosting to max clocks ever more seriously? The same CPU can be put into a competition mobo with ABB bios and boost properly, but not in the Crosshair VI. I appreciate you communicating with the community but actions speak louder than words and outright blaming AGESA isn't cutting it, otherwise, the issue would persist on ALL mobos and it is getting tiring repeating myself. It is affecting many other users across reddit, these forums and OC.net too.
    My 3600 hits 4.1Ghz max with the C6H when gaming it goes to 4075MHz and lower depending on temps. Yet in 2 separate brand boards with ABB it goes to 4.2Ghz max and around 4.2Ghz to 4150Mhz in games. So I am loosing 100mhz somewhere. Also, PBO and autoOC doesn't work and makes performance worse. Yet the same tests done on the other mobos gave me 4.3Ghz spikes and 4225Mhz - 4.2Ghz in games.
    Alternatively, on my C6H I can run a BCLK overclock with the default profile enabled in Ryzen master to allow stock boosting and voltage works perfectly. I can basically run it above MAX boost this way 100% stable. I just don't see why we have to use BCLK to get round UEFI issues. I'm considering buying a different brand mobo and leaving ASUS for the first time since 2003. But... With that said I am willing to help you resolve the issue and test any bios. I just want the correct performance. 4.2Ghz isn't breaking Zen2 limits and the BCLK overclock with boost proves it is capable with the C6H and the other boards prove it works properly without BCLK on the current ABB AGESA.
  2. #32
    ROG Enthusiast Array
    Sep 2017
    23
    39
    Quote Originally Posted by Richard_Dower View Post
    Can I bet that 7302 is a pre ryzen 3000 bios ?
    no, it is the first version of test bios posted by Shamino for c6h.
  3. #33
    ROG Member Array Alex656 PC Specs
    Alex656 PC Specs
    MotherboardCrosshair VI Hero
    ProcessorRyzen 9 3900x
    Memory (part number)F4-3200C14D-16GFX
    Graphics Card #1Gigabyte GTX 2080 Super
    MonitorDell S2417DG
    Storage #1Samsung 840 EVO 256 Gb
    Storage #2Toshiba 3TB DT01ACA300
    CPU CoolerNoctua NH-D15
    CaseCooler Master CM690 II
    Power SupplyThermaltake Toughpower 700W
    Aug 2019
    21
    Quote Originally Posted by Ryo_z View Post
    no, the issue is still occur even i manually set the correct dram and dram boot voltage.
    fyi, this issue also present in bios 7403/7401, but not on version 7302.
    Same here!
  4. #34
    New ROGer Array
    Aug 2019
    2
    This fixed the fan bug totally for me and my C7H Wifi. Thanks for this bios with the fix, I was a day away from buying a new motherboard to get away from this issue despite loving my C7H so much.
  5. #35
    New ROGer Array
    Aug 2019
    1
    The newest 7302 bios has this same issue. So far at random times either my PWM CPU fans or the AIO pump stop working, and my cpu temps rise to 95-105 and cpu freq drops to 500mhz. Gonna have to downgrade to this beta bios, but have to say im not really happy with my C7H purchase...
  6. #36
    New ROGer Array SKYBR PC Specs
    SKYBR PC Specs
    MotherboardCROSSHAIR VI HERO
    Processor3700X
    Memory (part number)GSKILL F4-3600C19D-32GVRB (@3733 16-20-20-36)
    Graphics Card #1GEFORCE 980 TI
    MonitorSAMSUNG U28E590D
    Storage #1SAMSUNG 850 EVO 500GB
    CPU CoolerCM MASTERLIQUID 240
    CaseTT CHASER A31 SNOW EDITION
    Power SupplyEVGA 750 BQ
    Keyboard A4TECH G800V
    Mouse LOGITECH G502
    Headset HYPERX CLOUD REVOLVER
    Network RouterCUSTOM DD-WRT
    Aug 2019
    4
    This beta BIOS apparently solved my C6H fan problem. Thank you!
  7. #37
    ROG Guru: Brown Belt Array gupsterg PC Specs
    gupsterg PC Specs
    MotherboardAsus Maximus VII Ranger
    Processori5 4690K
    Memory (part number)HyperX Savage 2400MHz 16GB
    Graphics Card #1Sapphire R9 Fury X (1145/545 Custom ROM)
    MonitorAsus MG279Q
    Storage #1Samsung 840 Evo 250GB
    Storage #2HGST 2TB
    CPU CoolerThermalRight Archon SB-E X2
    CaseSilverstone Temjin 06
    Power SupplyCooler Master V850
    Headset/Speakers HyperX Cloud
    OS Win 7 Pro x64 / Win 10 Pro x64
    gupsterg's Avatar
    Feb 2015
    103
    1,017
    UEFI 2703 & 0002 with SMU FW 46.34.00 for C7H & C7HWIFI in this post.
    Intel Defector AMD Rebel
    TR 1950X - Custom WC - Asus Zenith Extreme Alpha - G.Skill Trident Z 3400MHz C14 QC - RX VEGA 64
    R5 3600 - Custom WC - Asus Crosshair VII Hero Wifi - G.Skill Ripjaws V 3800MHz C16 - Sapphire HD 5850 Toxic
    24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
    Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
  8. #38
    ROG Enthusiast Array neotokyo PC Specs
    neotokyo PC Specs
    MotherboardROG Crosshair VII Hero
    ProcessorAMD R5 3600
    Memory (part number)2x8GB Ballistix Sport LT (BLS8G4D240FSC) @3200Mhz
    Graphics Card #1RTX 2070 WINDFORCE 8G
    MonitorLG 27UL650-W
    Storage #1WD Blue M.2 SATA 500GB
    Storage #2TOSHIBA P300 3TB/Crucial MX300 256GB
    CPU CoolerBe Quiet Dark Pro 4
    CasePhantek P600s
    Power SupplySeasonic Prime Ultra Platium 650W
    Mouse Logitech G403/502 Hero
    OS Windows 10
    Jun 2016
    51
    I had this glitch (finally) happen on Sunday with bios 2703 while I was packaging applications for deployment. The CPU cooler went down to 0RPM, then a couple of minutes later it's the case fans that started acting, like they were going down then ramping up almost immediately. The computer was back from sleep state when it happened, it didn't happen again for the couple of hours it was running it to package stuff after I rebooted. I couldn't test Sunday, but I'll try with 0002 during the week, I need to do CPU intensive work at some point before Friday.
    Edit: The case fans ramping up is because they're connected to the fan hub of the case, and, apparently, when the motherboard lowers the PWM to 0RPM, or below a certain threshold, the hub ramps up the fans to full speed instead.
  9. #39
    Feb 2018
    14
    77
    Can anyone reupload the C6H non wifi ones please. The dropbox links don't work any more
  10. #40
    ROG Member Array randydvd PC Specs
    randydvd PC Specs
    MotherboardCrosshair VI Hero BIOS 7302
    ProcessorRyzen 7 3700x
    Memory (part number)CMW16GX4M2D3600C18
    Graphics Card #1EVGA GTX 1080ti SC Black Edition Gaming
    MonitorAcer Predator X34A
    Storage #1Adata XPG SX8200 Pro 512gb
    Storage #2Crucial MX500 240gb
    CPU CoolerCryorig H7 Quad Lumi RGB
    CaseFractal Design Meshify C
    Keyboard Razer Blackwidow 2014 Tournament Edition
    Mouse Logitech G502 Proteus Core
    Headset Plantronics GameCom 780
    Mouse Pad Razer Goliathus Control Edition Extended
    Headset/Speakers Altec Lansing ADA 890
    OS Windows 10 Pro
    Accessory #1 Razer Mouse Bungee
    randydvd's Avatar
    Sep 2017
    9
    Quote Originally Posted by mikev190 View Post
    Yeah same for me, the file exceeded dropbox's download limit.
    Too many requests
    Sorry, this link has been automatically turned off for now. Learn more about traffic limits.
Tags for this Thread
