Results 1 to 10 of 13
08-19-2019 09:41 PM #1
Antrix PC Specs Laptop (Model) Microsoft Surface Pro 6 (i7, 16Gb, 1Tb) Motherboard Asus ROG Zenith Extreme Processor AMD Ryzen Threadripper 2990WX Memory (part number) G.SKILL Trident Z DDR4 128GB 3600 Graphics Card #1 Asus ROG MATRIX RTX 2080 TI Graphics Card #2 Asus ROG MATRIX RTX 2080 TI Monitor Samsung Curved C49RG90SSI 49" Storage #1 Samsung 970 Pro series 1TB M.2 Storage #2 Kingston HyperX Savage 480/960 Gb CPU Cooler Asus ROG Ryujin Aura OLED 360 Case Asus ROG Helios Power Supply Asus ROG Thor 1200W Keyboard Razer Huntsman Elite Mouse Razer Mamba HyperFlux Headset Asus ROG Centurion 7.1 Mouse Pad Razer Firefly HyperFlux Bundle Headset/Speakers Razer Nari Ultimate OS Windows 10 x64 Professional Network Router Asus RT-AC86U
- Join Date
- Jun 2018
- Reputation
- 10
- Posts
- 22
Maximus XI Extreme & 2x 2080 Ti Matrix NvLink
I built the following pc configuration (i mentioned only important components):
Processor: Intel i9-9900K
Memory: G.SKILL Trident Z DDR4 64GB 3600
Graphics Card #1: Asus ROG MATRIX RTX 2080 TI
Graphics Card #2: Asus ROG MATRIX RTX 2080 TI
Case: Asus ROG Helios
Power Supply: Asus ROG Thor 1200W
08-22-2019 01:58 AM #2
I am afraid that the top card will run hotter...
08-22-2019 06:41 PM #3
- Join Date
- Jun 2018
- Reputation
- 10
- Posts
- 22
Damn... any advice? Maybe i should put some fans on front?
08-23-2019 11:29 AM #4
- Join Date
- Jul 2019
- Reputation
- 10
- Posts
- 41
08-24-2019 12:59 AM #5
08-24-2019 02:12 PM #6
- Join Date
- Jun 2018
- Reputation
- 10
- Posts
- 22
Yeah, i really want to use it both via nvlink. The problem is that the size of those cards are a little higher in height and the bottom card does not fit due to usb / rgb / audio / power connectors, etc. What kind of motherboard can I choose for socket 1151, so that its dimensions would allow it to fit the second card normally? Well, or maybe there is something from 2066 or sTR4?
08-24-2019 04:05 PM #7
My concern with the 115X boards was always the low number of channels the CPU has... Whenever going with an SLI setup, I used the bigger boards - simply put, the ones with quad channel memory (those CPUs have more channels). So, Intel LGA 2011, 2011-v3, and LGA 2066: choose EATX, usually the PCIE slots are spaced pretty good for an SLI setup - however, the 3-slot graphics cards will be still pushing the limits...
Now, price-wise it worth considering the AMD boards too: also EATX, but only the X399 chipset ones - those are for the Threadripper CPUs. At this moment, I would wait though with these AMD boards... I have a feeling (from reading here and there) that AMD is coming out with the new Threadrippers soon...
The X570 AM4 platform would have enough PCIE lanes, but the dual channel memory setups are bothering me... That's why I was suggesting the X399 or it's successor...
Overall, your problem is with the 3-slot wide cards... not too many boards are designed to allow enough breathing room between them. As said before, placing water blocks over them is the easiest way to address the issue...*
08-24-2019 04:51 PM #8
- Join Date
- Jun 2018
- Reputation
- 10
- Posts
- 22
Thank you very much for the answers! Could you help me choose a motherboard for these video cards? I would really appreciate it. I don't want to put custom water blocks on them to avoid warranty removal. It doesn't matter which socket is 1151, 2066, or sTR4. Also, I will definitely thank you with anything.
08-24-2019 10:09 PM #9
- Join Date
- Jun 2018
- Reputation
- 10
- Posts
- 22
08-25-2019 08:02 PM #10
- Join Date
- Jun 2018
- Reputation
- 10
- Posts
- 22
Im planning to buy Asus ROG Rampage VI Extreme and i9-9980xe. What do you say, how much will I lose in terms of games performance (I know that this processor is designed for other tasks)?
