Page 1 of 16 1 2 3 11 ... LastLast
Results 1 to 10 of 151
    ROG Guru: Brown Belt Array LiveOrDie PC Specs
    LiveOrDie PC Specs
    MotherboardASUS RAMPAGE VI EXTREME OMEGA
    ProcessorIntel Core i9 10980XE 4.6Ghz 1.12v WC
    Memory (part number)G.Skill Trident Z RGB F4-3000C14D 64GB
    Graphics Card #1EVGA RTX 3080 XC3 ULTRA EK WB/BP
    MonitorLG 4k 43inch
    Storage #1Samsung 960 Pro NVME 1TB
    Storage #2Samsung 860 Evo 1TB x 3
    CPU CoolerEK-Velocity , EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
    CaseCorsair Obsidian 500D SE ATX-E Modded
    Power SupplyCooler Master V 1300W
    Keyboard Logitech G910
    Mouse Logitech G900
    Headset Razer Tiamat 2.2 v2
    OS Windows 10 x64
    Network RouterNetGear
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    ROG Rampage VI Extreme Encore
    ASUS today launched the Republic of Gamers (ROG) Rampage VI Extreme Encore socket LGA2066 motherboard. This board replaces the original ROG Rampage VI Extreme from the product-stack, but is positioned a notch below the Extreme Omega. It still has a beefy EATX PCB, but with slight variations to the layout. A few features such as the U.2 port are removed, while some of the connectivity options receive major updates. To begin with, the Extreme Encore features Wi-Fi 6 (802.11ax) WLAN (the Extreme Omega has the older 802.11ac standard). The Extreme Encore also features a 20 Gbps USB 3.2 Gen 2x2 port, which combines 10 Gbps wiring from two ports to a single port. The wired networking is unchanged, with a 10 GbE interface driven by an Aquantia controller, and a 1 GbE driven by an Intel i219-V.
    ASUS also reworked the CPU VRM compared to the original Rampage VI Extreme. The new Extreme Encore features a 16-phase CPU VRM with Infineon TDA21472 power-stages, and a large fan-heatsink with more surface-area than even the heatsink featured on the Extreme Omega. The memory VRM is a 4-phase (2+2 phase) setup. The expansion slot area has been made a little more usable, with x16, space, x4, x16, space x16, compared to the x16, double-space, x16, x4, x16 layout of the Extreme Omega. The Extreme Encore features the latest ROG design scheme, with even more acrylic aRGB diffusers. The rest of the board's feature-set is identical to that of the Extreme Omega. The ROG Rampage VI Extreme Encore is expected to be priced at USD $649.99.
    Source
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    So what are peoples thoughts on this board? Its pretty much the Omega with a few changes, It looks to have a color LCD panel rather than a LED one.
    ROG Guru: Brown Belt Array tistou77 PC Specs
    tistou77 PC Specs
    MotherboardRampage VI Extreme Encore
    Processor10980XE @4.6Ghz
    Memory (part number)G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    Graphics Card #1EVGA RTX 2080ti XC Ultra
    Sound CardXonar Phoebus
    MonitorDell U2417H
    Storage #1Intel Optane 905P PCIe
    Storage #2Samsung 970 EVO Plus
    CPU CoolerWatercooling
    CaseLian Li A77F
    Power SupplySeasonic Prime Ultra Titanium 1000W
    Keyboard Logitech LIK
    Mouse Logitech MX revolution
    OS Windows 10 Pro x64
    tistou77's Avatar
    Apr 2012
    109
    1,637
    Thanks for the info
    Difference with Omega ?
    Sorry for my english
    Case: Lian Li A77F
    MB: Rampage VI Extreme Encore
    CPU: i9 10980XE
    RAM: G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    GPU: EVGA RTX 2080ti XC Ultra
    PSU: Seasonic Prime Ultra Titanium 1000W
    OS: Intel Optane 905P PCIe
    DATA: Samsung 970 EVO Plus
    SOUND: Asus Xonar Phoebus
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    Quote Originally Posted by tistou77 View Post
    Thanks for the info
    Faster Wifi, 8x sata ports, no U.2, 4x M.2 slots, bigger VRM heatsink, color LED display, more RGBs, USB 3.2 and its cheaper.
    tistou77 PC Specs
    MonitorDell U2417H
    CaseLian Li A77F
    tistou77's Avatar
    Apr 2012
    109
    1,637
    Ok, thanks
    Always 1 less PCIe slot compared to the R6E
    USB 3.x must always be managed by ASMedia and not Intel
    the other 2 M2 are under the "shell" I guess ?
    Case: Lian Li A77F
    CPU: i9 10980XE
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    Ok, thanks
    The omega supports 4x m.2 but the Encore supports full size M.2s on both slots, when the omega doesn't due to its layout, which is why they have moved around the slots.
    Still its hardly a upgrade if your already on a Extreme or Omega, but the M.2 and VRM cooling is worth the upgrade from the normal Extreme.
    The power phases and the timing of this board I feel like Intel will drop a higher core count CPU on X299 very soon.
  7. #7
    tistou77 PC Specs
    MonitorDell U2417H
    CaseLian Li A77F
    tistou77's Avatar
    Apr 2012
    109
    1,637
    I'll wait to see if there will be another Rampage
    The layout of the PCIe on the Omega and Encore are not suitable for my PC
    Case: Lian Li A77F
    CPU: i9 10980XE
  8. #8
    ROG Guru: White Belt Array
    Dec 2011
    11
    100
    I'll pass on this one. No point in getting new blocks and breaking open my loop just for the sake of a lateral 'upgrade'.
  9. #9
    ROG Guru: Orange Belt Array
    Feb 2019
    67
    284
    losing PCIE lane and U2 is a deal breaker for me. When someone comes up with an M2 that will top the 905P AIC and U2 then ill take another look.
  10. #10
    ROG Enthusiast Array
    Sep 2014
    27
    This VRM should have no issues with a 9990XE (The auction CPU that draws about 650W)?
    Is the VRM better or worse than the Omega?
    Which board would you choose out of the two? I ask because i have a faulty Omega that i will be returning, and i may pick this up instead.. price isn't an issue, i just want the best performance.
