Voltage Colors
Somethingwhatev
Can someone explain the significance of the color changes when I manually set dram, vccio/sa voltages on the latest 2102 bios for maximus x formula? I have dram at 1.35v which is yellow while vccio and sa voltages are white at 1.1v each. when I raised the VCCIO voltage to 1.20000 it turned yellow then I couldn't change it back. I had to click and delete a bunch of times until it took. Setting it to 1.25000 turned it purple.
I don't understand why they make these boards for overclocking but refuse to give you tech support when you ask them simple questions about voltages, saying, "we don't support overclocking."
Zka17
Level 16
In general (on Asus ROG boards) the colors have a significance regarding safety: white - safe; yellow - your responsibility (usually means that left the safety zones, like for the VRAM by default is 1.2V, but the XMP is usually raising it to 1.35V); purple - unsafe (without proper cooling); red - dangerous (this usually is for liquid nitrogen)
It is all depending on your cooling solution - i.e. check your temps!
On older boards I have run voltages in the purple zone (Vcore, VRAM, VCCIO, VCCSA), but then I was in the OC game... nowadays, I am going for safety - meaning good temps with quiet cooling*
