Results 1 to 5 of 5
    ROG Member Array
    Jan 2018
    5
    Thumbs up G752VS Fn key/backlight issue
    Hey,
    My fn keys/backlight stopped working all of a sudden a couple months ago. I went through the threads and tried most of the suggestions... Reinstalling the ATK package didn't work (tried the one from the official website and an seemingly newer one I found floating in one of the threads here). Keyboard adjustment tool didn't work. Reinstalling Windows didn't work (including a completely fresh install). Updating drivers didn't work. Updating BIOS didn't work (currently on 312).
    I don't think it's a hardware issue and my laptop has been RMA'd for a different issue three times already, with varying success, so I'm hesitant about sending it in for just this. Obviously not an important enough problem, but annoying enough that once in a while I try to get it sorted out. Any tips?
    ROG Guru: Green Belt Array
    Nov 2012
    69
    730
    This is the ATK Package I use on my G752VSK:
    https://dlcdnets.asus.com/pub/ASUS/n..._VER100060.zip
    As for the keyboard backlights....it might be a bad keyboard. I had it happen on a G75VW, replaced keyboard and backlights were restored. By the way replacing the keyboard is like 30 screws. Mean job.
    Hey did you use your eSupport Folder (Run ASUS Installation Wizard) to restore all the ASUS drivers and programs after reinstalling Windows 10?
    G752VSK, G75VW-3D, G51J, G1S
    Homebuilt Windows Server
    ROG Member Array
    Jan 2018
    5
    Quote Originally Posted by jdfrench3 View Post
    Thanks for the reply. I tried that ATK package too but no luck. I didn't use the ASUS Installation Wizard but according to that everything is installed and up to date.
    Yeah, I'm generally unhappy with how inaccessible parts of this laptop are, and how badly it seems to react to pretty much anything. Do you think there is a way I could check whether it's a hardware/keyboard issue without replacing the keyboard? I think my 2 years warranty just ran out last month but I might be able to appeal that if I need replacement parts considering what had been done to the laptop during previous RMAs...
    Nov 2012
    69
    730
    Going through ASUS will cost.
    You could lift the top off and check that ribbon cables are all connected properly and connector latches closed.
    ROG Guru: Orange Belt Array navis995's Avatar
    Oct 2014
    50
    320
    If you replaced the motherbord then the backlight stops working and you have to do a mod that I uploaded the guide to in order to fix it.
    Asus Rog G750JZ
    Screen: 1920x1080 17.3'
    CPU: Intel® Core™ i7-4700HQ (3.4Ghz @ -70mV)
    GPU: GeForce GTX 880M 4GB (OC +125Mhz Core, +600Mhz Memory @ 1.062V)
    RAM: Samsung 32GB 1600MHz
    Storage #1: Samsung Evo 840 250GB
    Storage #2: Samsung Evo 850 500GB
    Storage #3: Seagate Barracuda 2TB
    Storage #4: Samsung Evo 128GB MicroSD
