3900X + CH7 WIFI + 2703 = BCLK can't stay at 100
loinad
@Shamino, 3900X + CH7 WiFi + BIOS 2703 = BCLK nevers stays at 100 even if manually set. HWiNFO says it's 98.8 and memory is 1581 (rather than 1600) and AIDA says 99.4 and 1590 memory. Auto and Default result in the same thing. In the BIOS it says 100 on the right side, though.
4 REPLIES 4
andyliu
might be wrong, but that sounds like you are using DOCP setting. change docp setting to manual should allow you to set the bclk to 100
loading DOCP profile = bclk @ 99.8.
Thanks, but I'm already on Manual and tried setting it to 100. No luck.
Hi, I had the same problem, reverted BLCK to Auto (just write it) and it now shows as 100.00 in monitoring programs.
gupsterg
Ryzen has no HW for accurate read back of BCLK.
Use Ai Tuner Manual, set BCLK 100MHz, when you open HWINFO, click settings, select tab safety, deselect periodic polling. Other apps may still show BCLK not as 100MHz, but when you setup HWINFO as stated you should see 100MHz.
Also use latest beta of HWINFO, Martin has updated how BCLK is calculated for Matisse.
Intel Defector :eek: AMD Rebel
R9 5900X - Custom WC - ASUS Crosshair VII Hero WiFi - Ballistix Sport LT 2x16GB 3800MHz C16 - RX 6800 XT - WD SN770 2TB - 2x 870 EVO 4TB
24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
:eek: CPU Validation 5.198GHz@1.314v with 4.4GHz cache + RAM 2400MHz@1T :eek:
Da Music video
