Prime x570 Pro cannot get Max Boost with 3900x on any cores
Tarvaln
I can't get any of my cores to hit 4.6Mhz at any time. These are the best numbers I could get out of 3 test per setting. I tested after midnight so the room is cool and let the PC cool for 10 minutes between each set of test. All on stock cooler. Cores were observed with Ryzen Master. All CPU setting were set with Ryzen Master.
Anyone else having this issue with 3900x? I'm starting to think it may be an issue with this chip not the whole 3000x line.
As stated above, MB is Asus Prime x570 Pro. BIOS 1005 with AGESA 1.0.0.3 Patch ABB. https://www.asus.com/us/Motherboards/PRIME-X570-PRO/HelpDesk_BIOS/
81573
I don't think anyone with a 3900x is getting a max boost of 4.6 under any conditions. I've made a consolidated topic on the AMD community forums about test results here https://community.amd.com/message/2927219
Please post a pic following the guidelines on the topic there if you are or are not hitting 4.6 Max boost with a 3900x. Thanks!
0 REPLIES 0
