Results 1 to 4 of 4
    New ROGer Array
    Aug 2019
    4
    Asus prime x570-pro and ryzen 7 3800x overclocking
    Hello to aIl.
    I am trying to overclock my new 3800x and ı achieved to 44.00Ghz..but its top value is 45.00..Anyone can help me about overclocking or any Asus authority can send me the settings here??..
    New ROGer Array
    Aug 2019
    2
    You probably won't be able to achieve an all-core OC to the advertised boost clock. I know its 4.5ghz for 3800X but you will see that number only on some cores in PBO single-core boost, if at all. Definitely bad marketing by AMD.
    New ROGer Array
    Aug 2019
    4
    ıdont thinkso.because it is going to 4.5ghz with hyper-v support.so it must be overclocked to 4.5 manually…
    help me please...
    New ROGer Array
    Aug 2019
    4
    Here is my bios settings for 4.4 ghz on prime x570-pro;
    Aİ overclock tuner:auto
    Performance enhancer:auto
    Memory frequency:3200 mhz (my rams are 3200 mhz)
    FCLK frequency:1600 mhz
    cpu core ratio:44.00
    TPU:keep current settings
    Performance bias:none
    Precision boost overdrive:disabled
    DIGI+VRM,cpu LLC:level 3
    soc LLC:level 2
    Cpu voltageffset mode
    auto
    SOC voltageffset mode
    auto
    Dram voltage:1.35000
    Bios Advanced mode;
    AMD overclockingrecision boost overdrive:disabled
    AMD CBS :core performance boost :disabled
    global c-state:disabled
    NBIO common options:XFR enhancementrecision boost overdrive:disabled
    These are my settings for ryzen 3800x
    And ı am waiting for your helps to go 4.5 ghz
    Thank you
