Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    ROG Guru: Yellow Belt Array XYchromosone PC Specs
    MotherboardASUS Maximux XI Extreme [BIOS 1401]
    Processori9 9900KS
    Memory (part number)G.Skill Trident Z RGB CL17 3600MHz 32GB [4x8]
    Graphics Card #1ASUS ROG Strix Gaming GTX 1080Ti 11GB
    MonitorAOC AGON AG271QG 27" 144Hz-165Hz OC
    Storage #1Samsung 970 Pro NVMe 1TB M.2 SSD
    CPU CoolerThermaltake Floe Riing 360 Premium AIO
    CaseFractal Design Define R6 Black
    Power SupplyCorsair AX1600i
    Keyboard RAZER Blackwidow X Tournament Chroma
    Mouse RAZER Lancehead [ambidextrous] Chroma
    Headset Sennheiser RS165 Wireless
    Headset/Speakers Sennheiser CX 100 inner ear headphones
    OS Windows 10 Pro x64 + Ubuntu Studio 19.04
    Network RouterASUS DSL-AC68U on ADSL2+, Technicolor DJA0230TLS Gateway, Netgear Cable Adapter CM450
    XYchromosone's Avatar
    Dec 2015
    30
    245
    Quote Originally Posted by AAtte View Post
    I just bought Strix X570-I and my chipset temps to go 67 while idle and my chipset fan is at 5000RPM. How can I fix this?
    I suggest to get a 10 K ohm thermister [the common PTC or "Positive Temperature Coefficient" type] and plug it in to a 2 pin extension heat sensor input on your mobo, which I would think actually has one of those 2 pin sensor inputs. Then tape the thermister end of the cable to the PCH to monitor the chipset's temp. This will bring up a monitor setting in your fan control in the BIOS so you can pick the extension thermister as a source for fan speed control. But if your BIOS does not have this functionality, then I am not sure what else you can do.
    You can purchase these 10k thermister cables with a 2 pin header at one end for your mobo, or if you're a handy person you can make it yourself, it's easy. I have a photo of two thermister cables that I soldered the 10k thermister at one end of an old DVD burner digital audio cable that also uses the 2 pin format as the ASUS mobos do. If you are a long toothed PC builder you should have a spare ODD digital cable that you can use. Just cut off one end and keep the female 2 pin header on the other end. Purchase a 10k PTC thermister from a local electronics part supplier such as radio shack etc. or search online and solder the thermister to the opposite cut end of the cable. I use heat shrink tubing to slide over each leg of the thermister before soldering, then use a cigarette lighter to heat shrink the tubing placed over the solder joint to prevent the 2 legs of the thermister from shorting out. Then i put another length of tubing over the whole thermister and also up to about 1 cm or 1/2 inch of the cable and heat shrink the tubing to protect the thermister.
  2. #12
    New ROGer Array
    Jan 2020
    3
    Quote Originally Posted by XYchromosone View Post
    Actually not a bad idea. One of those thermal sensors came included with my Strix X570-e. Unfortunately, I couldn't find any setting so change the PCH Fan source in my BIOS.
    It's funny how other manufacturers patched the option to adjust their PCH fans back in August.
